[mapserver-users] Mapserver SQL Server 2008 R2 connection
Tamas Szekeres
szekerest at gmail.com
Wed Nov 10 04:27:30 EST 2010
Milen,
According to the timestamps this compilation seems to be outdated and there
have been lost of changes in the mssql2008 driver afterwards.
I suggest to do a test with the daily build packages from
http://vbkto.dyndns.org/sdk/ by replacing .exe and .dll files to the newer
versions.
Best regards,
Tamas
2010/11/10 Milena <mgebreab at maxgeo.com>
> Hi All,
> I really appricate any help on this.
> I am trying to create a WMS using mapserver and data from SQL 2008 R2. This
> is what my map file looks like.
> SIZE 600 800
> PROJECTION
> "init=epsg:4326" #latlon on WGS84
> END
> EXTENT 113 -34 129 -14
> # lon/lat extents of Spatial
> WEB
> IMAGEPATH "/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> METADATA
> "map" "C:/OSGeo4W/apps/Spatial/config.map"
> "ows_schemas_location" "http://schemas.opengeospatial.net"
> "ows_title" "Sample WMS"
> "ows_abstract" "Sample WMS of Spatial"
> "ows_keywordlist" "Spatial,WMS,Maxwell"
> "ows_onlineresource"
> "http://localhost:8080//Spatial?map=C:/OSGeo4W/apps/Spatial/config.map&"
> "wms_srs" "EPSG:4326" #latlon
> "wms_feature_info_mime_type" "text/plain"
> "wms_feature_info_mime_type" "text/html"
> "wms_server_version" "1.1.1"
> "wms_formatlist" "image/png,image/gif,image/jpeg"
> "wms_format" "image/gif"
> END #metadata
> END #web
> LAYER
> NAME "tenements"
> CONNECTIONTYPE PLUGIN
> PLUGIN "C:/OSGeo4W/specialplugins/msplugin_mssql2008.dll"
> CONNECTION "Provider=SQLOLEDB.1;Integrated Security=SSPI;Persist Security
> Info=False;Initial
> Catalog=SpatialDB;Data Source=AU-FRE-L0217//SQL_2008R2"
> DATA "SP_GEOMETRY from dbo.tenements"
> TYPE POLYGON
> STATUS ON
> METADATA
> "ows_title" "tenements"
> END #metadata
> PROJECTION
> "init=epsg:4326"
> END
> END #Layer
> End #Map
> I am using msplugin_mssql2008.dll plugin. But I keep getting 500 internal
> error:
> I checked the even view and the error there says:
> Faulting application name: mapserv.exe, version: 0.0.0.0, time stamp:
> 0x4ab3c473
> Faulting module name: libmap.dll, version: 0.0.0.0, time stamp: 0x4ab3c46e
> Exception code: 0xc0000005
> Fault offset: 0x000a7815
> Faulting process id: 0x178c
> Faulting application start time: 0x01cb80a63078252e
> Faulting application path: C:\OSGeo4W\bin\mapserv.exe
> Faulting module path: C:\OSGeo4W\bin\libmap.dll
> Report Id: 6f925ed2-ec99-11df-a20d-b8ac6f7484b2
> Appache error log error message is:
> [Wed Nov 10 13:56:35 2010] [error] [client 127.0.0.1] Premature end of
> script headers: mapserv.exe
> [Wed Nov 10 13:59:04 2010] [error] [client 127.0.0.1] Premature end of
> [Wed Nov 10 15:09:21 2010] [error] [client 127.0.0.1] Premature end of
> Please help!!
> Thank you
> Milen
> http://osgeo-org.1803224.n2.nabble.com/Mapserver-SQL-Server-2008-R2-connection-tp5723789p5723789.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101110/df85bf22/attachment.html
