[mapserver-users] Another newbie needing help with a mapfile
(projections)...
adams
adams at terrestris.de
Thu Nov 11 08:43:22 EST 2010
Dear MM,
I guess your problem is the
SHAPEPATH "."
Try first to add the full OR relative (from where your *.map is)
datapath in your data-statement of the layer, e.g. :
DATA /this/is/the/path/to/mattarello.shp
If that works, add that path to your shapepath
Till
MM wrote:
> Hello!
> I have a problem with Mapserver which I am apparently unable to solve.
> I have a mapserver installation which is queried by a web component,
> that uses virtual earth tile addressing. It works really great. My web
> component queries it like this:
> http://localhost/MapServ/mapserv.exe?map=mymap.map&mode=tile&tilemode=ve&tile=1202213133323032212&layers=aaa
> Until now it worked with ECW files only, and I had no problems. But
> now I need to add a shape file, and I just can't get it to work! I
> googled extensively the whole morning but I was unable to find any
> solution.
> Ogrinfo says this:
> INFO: Open of ... using driver `ESRI Shapefile' successful.
> Layer name: mattarello
> Geometry: Polygon
> Feature Count: 8270
> Extent: (662941.920131, 5093593.286658) - (667764.802144, 5099438.607073)
> Layer SRS WKT:
> PROJCS["UTM Zone 32, Northern Hemisphere",
> GEOGCS["GRS 1980(IUGG, 1980)",
> DATUM["unknown",
> SPHEROID["GRS80",6378137,298.257222101]],
> PRIMEM["Greenwich",0],
> UNIT["Degree",0.017453292519943295]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",9],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0],
> UNIT["Meter",1]]
> ogc_fid: Integer (10.0)
> This map has the same extent as the ecw I am using and it was provided
> by the same person, so I just thought to use the same projection as
> the ECW. I also thought that the output projection should be the same
> as the one I am using with the ECW, to work with the web component.
> Unfortunately, all tiles I get are just blank, and calling mapserver
> in map mode also renders a blank map.
> If I comment out the projection inside the layer, calling mapserver in
> map mode, it displays the map. But the tile is still blank.
> I am probably using the wrong projection, but I really can't figure
> out how to find the correct one, or how to translate the ogrinfo
> information to the mapfile!
> Here is the mapfile I am using.
> MAP
> IMAGETYPE PNG
> EXTENT 662941.920131 5093593.286658 667764.802144
> 5099438.607073
> SIZE 400 400
> SHAPEPATH "."
> IMAGECOLOR 255 255 255
> CONFIG "MS_ERRORFILE" "mapserverlog.txt"
> CONFIG "PROJ_DEBUG" "ON"
> DEBUG 5
> OUTPUTFORMAT
> NAME png
> DRIVER "GD/PNG"
> MIMETYPE "image/png"
> IMAGEMODE RGB
> EXTENSION "png"
> END
> LAYER
> NAME aaa
> TYPE POLYGON
> DATA mattarello.shp
> STATUS DEFAULT
> CLASS
> NAME aaa
> OUTLINECOLOR 255 0 0
> END
> PROJECTION
> "proj=utm"
> "zone=32"
> "ellps=GRS80"
> "units=m"
> "no_defs"
> END
> END
> PROJECTION
> "proj=merc"
> "a=6378137"
> "b=6378137"
> "lat_ts=0.0"
> "lon_0=0.0"
> "x_0=0.0"
> "y_0=0"
> "k=1.0"
> "units=m"
> "nadgrids=@null"
> "wktext"
> "no_defs"
> END
> END
> Is there a way to display this shape on the tile?
> Thanks for any help!!!
> Palantir
> mapserver-users at lists.osgeo.org
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams at terrestris.de http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
