[mapserver-users] multi criteria visualization on vector
Simone Frigerio
simone.frigerio at univie.ac.at
Fri Nov 12 13:08:34 EST 2010
Hi folk,
one question on visualization based on logic criteria.
I have a huge vectorial shp file (thousand of records). An example of
attributes as following:
__
Shape A B C D COMBI
Polygon 0 0 3 4 0_0_3_4
Polygon 0 0 3 0 0_0_3_0
There are 25 combination of the 4 fields A-B-C-D visualized by unique
code in COMBI field.
I managed a mapfile like:
LAYER
NAME "MH"
TYPE POLYGON
DATA "melanie/topo"
TRANSPARENCY 35
GROUP "MASCHERA"
STATUS ON
TEMPLATE "ttt"
CLASSITEM "COMBI"
CLASS
EXPRESSION "0_0_3_0"
STYLE
COLOR 25 255 255
OUTLINECOLOR 0 0 0
END
END
END
I visualize in this way only the polygons with the value in COMBI field.
I can obviously add same class expressions for every value I want. My
doubt is:
if I need to visualize all the "n" combination available like
differently "n" layers in a same view how can I do? I have to separate
the original file in 25 shp layers (quite boring) or can I provide using
only the original complete shp file?
Example on the layer tree:
Thanks.
Simone
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101112/1f8e11fd/attachment.html
