[mapserver-users] multi criteria visualization on vector
Alexander Petkov
greenkov at gmail.com
Fri Nov 12 13:42:21 EST 2010
The classes are fine for defining your 25 combinations to make them
look the way you want to.
To the question about your shapefile--you could keep as one shapefile
and define you connection to the data as shown here:
http://mapserver.org/input/vector/ogr.html
Define a static filter at first to test.
Then, when that works, you can use variable substitution:
http://mapserver.org/mapfile/variable_sub.html
At least that's what I'd try.
Alex
On Fri, Nov 12, 2010 at 11:08 AM, Simone Frigerio
<simone.frigerio at univie.ac.at> wrote:
> Hi folk,
> one question on visualization based on logic criteria.
> I have a huge vectorial shp file (thousand of records). An example of attributes as following:
> ShapeABCDCOMBI
> Polygon00340_0_3_4
> Polygon00300_0_3_0
> There are 25 combination of the 4 fields A-B-C-D visualized by unique code in COMBI field.
> I managed a mapfile like:
> LAYER
> NAME "MH"
> TYPE POLYGON
> DATA "melanie/topo"
> TRANSPARENCY 35
> GROUP "MASCHERA"
> STATUS ON
> TEMPLATE "ttt"
> CLASSITEM "COMBI"
> CLASS
> EXPRESSION "0_0_3_0"
> STYLE
> COLOR 25 255 255
> OUTLINECOLOR 0 0 0
> END
> END
> END
> I visualize in this way only the polygons with the value in COMBI field. I can obviously add same class expressions for every value I want. My doubt is:
> if I need to visualize all the "n" combination available like differently "n" layers in a same view how can I do? I have to separate the original file in 25 shp layers (quite boring) or can I provide using only the original complete shp file?
> Example on the layer tree:
> Thanks.
> Simone
> mapserver-users at lists.osgeo.org
