RE: RE: [mapserver-users] Gauss-Krüger
Daiane Fraga
daiane.a.fraga at gmail.com
Tue Nov 16 06:15:57 EST 2010
I'm sorry, but did not understand what you mean.
My problem is that I'm with the map in the coordinate system outdated (the
maps are dated from 1908). I'm not sure that I have known maps in a
Mapserver projection. And I'm using an application that interacts with
Google Maps, which has caused problems.
We can do the conversion to the WGS 1984, but it has to be done manually for
each map.
I would like to automatically convert the Gauss-Krüger projection to a
knownMapserver projection, as the coordinate system WGS.
I'm actually using this:
PROJECTION
"Init = EPSG: 26915"
"Proj = latlong"
"Ellps = WGS84"
"Datum = WGS84"
END
Thanks!
Daiane Fraga
---------- Forwarded message ----------
From: Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
Date: 2010/11/12
Subject: Re: [mapserver-users] Gauss-Krüger
To: Daiane Fraga <daiane.a.fraga at gmail.com>, mapserver-users at lists.osgeo.org
See examples of, for example, the Finnish KKJ which is a Gauss-Krüger
projection.
http://spatialreference.org/ref/epsg/2393/mapfile/
http://spatialreference.org/ref/epsg/2392/mapfile/ #another zone
These settings work always but if the projection string is included in the
"epsg" file in the "proj" directory it is possible to make it shorter and
have just "init=epsg:2393" as a projection in the mapfile.
-Jukka Rahkonen-
*Lähettäjä:* mapserver-users-bounces at lists.osgeo.org [mailto:
mapserver-users-bounces at lists.osgeo.org] *Puolesta *Daiane Fraga
*Lähetetty:* 12. marraskuuta 2010 17:03
*Vastaanottaja:* mapserver-users at lists.osgeo.org
*Aihe:* [mapserver-users] Gauss-Krüger
Hello,
Did someone have any problems using Mapserver with Gauss-Krüger?
I know that Mapserver is compatible with proj.4 library and the proj.4
library supports Gauss-Krüger. But I dont know how to use it.
Somebody could help me?
Thanks.
Daiane
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101116/9a8a02b5/attachment.html
