[mapserver-users] Re: fedora 14 cannot find -lpgport
Sebastian E. Ovide
sebastian.ovide at gmail.com
Thu Nov 18 06:03:03 EST 2010
>From the Fedora mailing list:
For some (reasonable) reason, usually Fedora strongly discourages to ship
static archives in binary rpms:
https://fedoraproject.org/wiki/Packaging/Guidelines#Packaging_Static_Libraries
You can see this also happened on postgresql:
http://pkgs.fedoraproject.org/gitweb/?p=postgresql.git;a=commitdiff;h=a6a1e9bfab6192bbdaea41e88368ae7d242316d7
You should really check if libpgport.a is really needed, i.e.
check it the package you are trying to build supports dynamic
linkage (against libpgport.so).
On Thu, Nov 18, 2010 at 10:22 AM, Julien Cigar <jcigar at ulb.ac.be> wrote:
> On 11/18/2010 10:35, Sebastian E. Ovide wrote:
>> from
>> http://forums.fedoraforum.org/showthread.php?p=1417824#post1417824 it
>> looks like libpgport isn't supported by fedora...
>> Is there any other way to build MapServer without that library ?
> disable Postgis support ?
> I don't use Fedora, but I reported a similar problem with the FreeBSD port,
> which looks like yours: http://www.freebsd.org/cgi/query-pr.cgi?pr=145002
>> On Wed, Nov 17, 2010 at 3:49 PM, Sebastian E. Ovide
>> <sebastian.ovide at gmail.com <mailto:sebastian.ovide at gmail.com>> wrote:
>> Hi Guys,
>> I'm building mapserver in Fedora 14 and getting
>> /usr/bin/ld: cannot find -lpgport
>> collect2: ld returned 1 exit status
>> doing
>> yum list | grep pgport
>> and
>> yum provides "*pgport*"
>> I cannot see any package with pgport...
>> any ideas ?
>> Sebastian E. Ovide
>> Sebastian E. Ovide
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> No trees were killed in the creation of this message.
> However, many electrons were terribly inconvenienced.
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101118/03dd5390/attachment.html
