Re: [mapserver-users] Mapserver + OCI error while loading shared libraries from Apache ?
Ivan Lucena
ivan.lucena at pmldnet.com
Thu Nov 18 12:01:18 EST 2010
Sebastian,
> -------Original Message-------
> From: Sebastian E. Ovide <sebastian.ovide at gmail.com>
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] Mapserver + OCI error while loading shared libraries from Apache ?
> Sent: Nov 18 '10 11:54
> Hi All,
> everything is working find from shell. I register the Oracle libraries with
> ldconfig, I have even created a cgi that set the LD_LIBRARY_PATH
> [gis at mapserver-fc14 cgi-bin]$ cat test.sh
> #!/bin/sh
> export ORACLE_HOME=/home/gis/libs/instantclient_11_2/
> export LD_LIBRARY_PATH=/home/gis/libs/instantclient_11_2/
> /var/www/cgi-bin/mapserv $*
> and still getting
> [Thu Nov 18 16:50:06 2010] [error] [client 10.0.1.50]
> /var/www/cgi-bin/mapserv: error while loading shared libraries:
> libclntsh.so.11.1: cannot open shared object file: No such file or
> directory
Does that message means that the error occurs during the process of loading libclntsh.so.11.1 and therefor that library was found but that library is trying to load another one that is not on the path?
> [Thu Nov 18 16:50:06 2010] [error] [client 10.0.1.50] Premature end of
> script headers: test.sh
> any ideas ?
> note: this problem is on a Fedora 14--
> Sebastian E. Ovide
> [LINK: compose.php?to=mapserver-users at lists.osgeo.org]
> [LINK: http://lists.osgeo.org/mailman/listinfo/mapserver-users]
