[mapserver-users] msProcessProjection(): Projection library
error. no system list, errno: 2
Sebastian E. Ovide
sebastian.ovide at gmail.com
Thu Nov 18 12:55:05 EST 2010
solved with
yum install proj-epsg
On Thu, Nov 18, 2010 at 5:31 PM, Michael Schulz <mschulz at webgis.de> wrote:
> Hi,
> the projection-lib cannot find the epsg file, where all the
> projections are defined. Add
> CONFIG "PROJ_LIB" "/usr/local/share/proj/nad"
> your mapfile (you may have to adjust the path).
> Cheers, Michael
> 2010/11/18 Sebastian E. Ovide <sebastian.ovide at gmail.com>:
> > Hi All,
> > I'm using an map file that works fine on one server, but for some reason
> on
> > another server (just installed: Fedora) it is giving this error:
> > [Thu Nov 18 17:23:03 2010].578122 msProcessProjection(): Projection
> library
> > I've already set DEBUG 5 and CONFIG "CPL_DEBUG" "ON" bat I cannot find
> any
> > extra information that could help to understand what the problem is..
> (I've
> > built mapserver with debug flag)
> > any ideas ?
> > Sebastian E. Ovide
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Michael Schulz
> in medias res
> Gesellschaft für Informationstechnologie mbH
> Schwimmbadstraße 2
> D-79100 Freiburg i. Br.
> Tel: +49 (0)761 705798-102
> Tel: +49 (0)761 705798-0
> Fax: +49 (0)761 705798-09
> http://www.webgis.de / http://www.zopecms.de
> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101118/90349954/attachment-0001.html
