[mapserver-users] Re: EPSG:4326 with WMS 1.3.0
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Sun Nov 21 10:38:29 EST 2010
vheurteaux wrote:
> Hello Jukka,
> You said "You may see rotated maps if you open gml vector data returned by
WFS 1.1.0 service with a client than can't handle axis flipping but that is
a client error".
> Do we agree that the server is expected to return a rotated map, and that
the client is expected to put it back in the right orientation?
Not really, I fear. Even WFS server does not send rotated maps, it is sending normally oriented vector maps with coordinates in order northing-easting with some projections. The vector map client is expected to parse the coordinates correctly by following the projection definitions. For example UTM zones are always easting-northing and WFS output from versions 1.0.0 and 1.1.0 have the same axis order.
> Do we agree that on a client with no such capability (for example when
viewing the image directly in the internet browser), the image in EPSG:4326
shall appear rotated?
WMS is sending images as they should appear on the screen and client is not supposed to do any pixel-by-pixel warping. Only thing that a proper WMS 1.3.0 client need to do is to build BBOX with correct axis order, either easting-northing or northing-easting. A not-proper WMS 1.3.0 client will build BBOX with wrong axis order (again, with some projections) and get back a north-up image from some other place of the world, not a rotated image.
-Jukka Rahkonen-
Cheers
Vincent
View this message in context: http://osgeo-org.1803224.n2.nabble.com/EPSG-4326-with-WMS-1-3-0-tp5756000p5757819.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
