[mapserver-users] SLD and OUTPUTFORMAT compatibility?
Martin Ouellet
geomartino at gmail.com
Tue Nov 23 09:15:12 EST 2010
Hi all,
I have 2 two differents settings for symbolize my lines (refer to SLD
settings below):
1) a dashed line which is working *only when I specify the
outputformat: *DRIVER
"*GD*/PNG"
**Note that with the driver GD/PNG, the external graphic below is not
working but the symbol (ico-ulaval-flag.gif) is copied locally in the
/ms_tmp directory.
It seem to be ignored by mapserver (but raising no error)...
2) a external graphic which is working *only when I specify the
outputformat: *DRIVER "*AGG*/PNG"
Q: Is there a way/config to support both at the same time?
any advice?
Thanks you in advance!
MartinOuellet
SLD settings:
______________________________________________________________________________________
<!--line with a dashed pattern->
<se:LineSymbolizer>
<se:Stroke>
<sld:CssParameter name="stroke">#000A99</sld:CssParameter>
<sld:CssParameter name="stroke-dasharray">6.0 2.0 1.0 2.0 1.0 2.0 1.0
2.0 4.0</sld:CssParameter>
<sld:CssParameter name="stroke-width">1.0</sld:CssParameter>
</se:Stroke>
</se:LineSymbolizer>
<!--line with a external graphic symbol->
<se:LineSymbolizer>
<se:Stroke>
<se:GraphicStroke>
<se:Graphic>
<ExternalGraphic>
<OnlineResource xlink:type="simple" xlink:href="
http://www.fsi.ulaval.ca/typo3conf/ext/Annuaire_facultaire/images/ico-ulaval-flag.gif
<Format>image/gif</Format>
</ExternalGraphic>
<Size>10.0</Size>
</se:Graphic>
</se:GraphicStroke>
</se:Stroke>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101123/ebbcb1b2/attachment.html
