[mapserver-users] RE: querying to getting bounding box coordinates
David Hildebrand
David.Hildebrand at afsc.ca
Tue Nov 23 18:58:40 EST 2010
I wanted to retain WMS compatibility but the WMS protocol does not seem
to support attribute queries. I know I can use GetFeatureInfo to get
attributes including the bounding box of the feature because these are
CGI variables. However, GetFeatureInfo uses a spatial query (an image
point). If I use MapServer's mode=itemquery what would be the URL
syntax and the requirements on the server side? Would I be able to
specify or determine the projection?
Thanks for your help.
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
www.afsc.ca <http://www.afsc.ca>
This communication is intended for the use of the recipient to which it
is addressed, and may contain confidential, personal and/or privileged
information. Please contact Agriculture Financial Services Corporation
immediately if you are not the intended recipient of this communication,
and do not copy, distribute, or take action relying on it. Any
communication received in error, or subsequent reply, should be deleted
or destroyed. Please consider the environment before printing this
email.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Lime,
Steve D (DNR)
Sent: Tuesday, November 23, 2010 3:52 PM
To: David Hildebrand; mapserver-users at lists.osgeo.org
Subject: [mapserver-users] RE: querying to getting bounding box
coordinates
Are you limited to WMS/WFS or can you use stock MapServer queries?
Passing in
a parcel id and returning it's bounding box is trivial using
mode=itemquery and
a template.
Steve
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of David
Hildebrand
Sent: Tuesday, November 23, 2010 2:49 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] querying to getting bounding box coordinates
I am running a WMS service with Mapserver in a Windows environment. I
want to be able to run a non-spatial query on a parcel layer to return
the bounding box (in re-projected coordinates) for a particular parcel.
The bounding box and projection will then be used in a WMS query to
return a map image.
I've never coded server-side functionality with Mapserver so any
suggestions would be welcome.
Thanks to all.
David V. Hildebrand
(403) 782-8239
email.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
