[mapserver-users] Changing map file parameter (Label Color) via URL
myOpenLayersUName
joanne.mcgraw at SYMPATICO.CA
Wed Nov 24 12:04:18 EST 2010
Hello,
Can someone help me out with the proper syntax for the following? Or, tell
me outright that it is not possible?
I've been trying to apply the documentation found on the MapServer CGI
Controls page
(http://www.mapserver.org/cgi/controls.html#changing-map-file-parameters-via-a-form-or-a-url)
under the "Changing map file parameters via a form or a URL" section but
have not had any luck applying it to change the colour of the label text.
I have a basic URL in which I pass the coordinates for a point and provide
the label text as follows:
http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/wms/dynamicWms/map/dynamicWms.map&map.layer[resultlabel]=FEATURE
POINTS -749340.32786036 180081.55026124 END TEXT 'Fence 1'
END&LAYERS=resultlabel&FORMAT=image/png&SRS=EPSG:42304&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application/vnd.ogc.se_inimage&BBOX=-910537.6366469,102726.53880899,-587878.43588336,261873.32786947&WIDTH=1219&HEIGHT=601
I would further like to set the colour of the point symbol and its label
text within the URL.
At this point, I am able to set the point symbol's colour by adding
"&map.layer[resultlabel].class[0]=COLOR 255 0 0"; but I can't seem to change
the label text's colour. It is always black. I've tried adding
"&map.layer[resultlabel].class[0].label[0]=COLOR 255 0 0" and
"&map.layer[resultlabel].class[0].label=COLOR 255 0 0" to no avail.
If it matters, my map layer is defined as follows:
LAYER
NAME "resultlabel"
STATUS ON
TYPE point
PROJECTION
"init=epsg:42304"
END
METADATA
"wms_title" "Result Label"
END
CLASS
SYMBOL "thickcrosshair"
SIZE 9
COLOR 0 0 0
LABEL
TYPE truetype
FONT arial-bold
SIZE 10
COLOR 0 0 0
OUTLINECOLOR 255 255 255
POSITION ur
FORCE ON
END
END
END
Does anyone know if this is this just a syntax problem that I am having or
if changing the label text's colour is just not supported?
Cheers,
jtm
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Changing-map-file-parameter-Label-Color-via-URL-tp5771138p5771138.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
