[mapserver-users] Join from SHP file to PostgreSQL table
Carlos Ruiz
boolean10001 at yahoo.com
Mon Nov 29 10:38:11 EST 2010
Flavio,
Column names are case sensitive, have you checked this ?
Cheers from México
IC Carlos Ruiz
To: mapserver-users at lists.osgeo.org
Sent: Mon, November 29, 2010 8:43:44 AM
Subject: [mapserver-users] Join from SHP file to PostgreSQL table
I need to make a layer with a join between a shapefile and a non-spatial
table, stored on PostgreSQL. I've found this documentation
(http://mapserver.org/mapfile/join.html) but i could make it work, so, can u
guys help me looking at this configuration and tell me whats wrong?
LAYER
NAME "join_shape"
TYPE POLYGON
STATUS DEFAULT
DATA "join_shapefile.shp"
CLASS
NAME "Joined Shapes"
STYLE
OUTLINECOLOR 120 120 120
COLOR 0 30 255
END
END
TOLERANCE 20
JOIN
NAME "teste"
CONNECTION "dbname='testdb' host=GSERVER1 port=5432
user='test'
password='test' sslmode=disable"
CONNECTIONTYPE ogr
TABLE '"test"."nonspatial"'
FROM "code"
TO "code"
TYPE ONE-TO-ONE
END
END # layer
In this layer, i want to show only the geometrys in the shapefile
"join_shapefile.shp" that have a CODE column that is the same the CODE
column in the test.nonspatial table, stored on Postgre.
That is possible?
Thanks again
Regards,
Flavio Carmo
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Join-from-SHP-file-to-PostgreSQL-table-tp5784531p5784531.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101129/e61390a1/attachment.html
