[mapserver-users] Join from SHP file to PostgreSQL table
Brent Fraser
bfraser at geoanalytic.com
Mon Nov 29 10:46:16 EST 2010
Flavio,
I think that if you have CONNECTIONTYPE OGR, the connection string
must have "PG:" (unlike the native mapserver Postgres connections?):
CONNECTIONTYPE ogr
CONNECTION "PG:dbname='testdb' host=GSERVER1 port=5432 user='test'
password='test' sslmode=disable"
If this works let me know, and I'll change the join documentation
Best Regards,
Brent Fraser
On 11/29/2010 7:43 AM, flaviocarmo wrote:
> Hi,
> I need to make a layer with a join between a shapefile and a non-spatial
> table, stored on PostgreSQL. I've found this documentation
> (http://mapserver.org/mapfile/join.html) but i could make it work, so, can u
> guys help me looking at this configuration and tell me whats wrong?
> LAYER
> NAME "join_shape"
> TYPE POLYGON
> STATUS DEFAULT
> DATA "join_shapefile.shp"
> CLASS
> NAME "Joined Shapes"
> STYLE
> OUTLINECOLOR 120 120 120
> COLOR 0 30 255
> END
> END
> TOLERANCE 20
> JOIN
> NAME "teste"
> CONNECTION "dbname='testdb' host=GSERVER1 port=5432
> user='test'
> CONNECTIONTYPE ogr
> TABLE '"test"."nonspatial"'
> FROM "code"
> TO "code"
> TYPE ONE-TO-ONE
> END
> END # layer
> In this layer, i want to show only the geometrys in the shapefile
> "join_shapefile.shp" that have a CODE column that is the same the CODE
> column in the test.nonspatial table, stored on Postgre.
> That is possible?
> Thanks again
> Regards,
> Flavio Carmo
