[mapserver-users] Re: Join from SHP file to PostgreSQL table
flaviocarmo
flavio.o.carmo at gmail.com
Mon Nov 29 14:21:57 EST 2010
Thanks all for your responses. Im a novice in Mapserver so, after reading,
now i know that:
- I cant use a JOIN to shown only geometrys with the CODE field stored on
Postgres (or another Database) because joins cannot modify the look of a
map;
- I need to use a template always to show the queries results;
- Case-sensitive fields can be a problem in a query with mapserver;
- The "PG:" string for was my mistake. I missed in the mail, but was in my
MAP file. Sorry.
Now what? There isnt a way to solve my issue? My client needs a opensource
solution to deliver his data. His current solution (ESRI ArcGIS Server) is
too expensive to buy another license, so he asked for a solution with the
same quality, but opensource.
There is a way to workaround this?
Thanks again.
Regards,
Flavio Carmo
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Join-from-SHP-file-to-PostgreSQL-table-tp5784531p5785616.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
