[mapserver-users] Re: Join from SHP file to PostgreSQL table
Brent Fraser
bfraser at geoanalytic.com
Mon Nov 29 15:18:34 EST 2010
Flavio,
I'm currently experimenting with joining a shapefile to a MS Access
file using OGR and ODBC (and stock mapserver v 5.2.1 from MS4W). Works ok:
CONNECTIONTYPE OGR
CONNECTION 'G:/GeoData/Parcels/Alberta/t_505033.shp'
DATA "SELECT * FROM t_505033 LEFT JOIN 'ODBC:Parcels_Rural'.basic
ON t_505033.PID=basic.PID"
I'm able to use a column in the ODBC datasource as the CLASSITEM for
rendering. You should be able to do the same with an ODBC datasource
pointing to a PostGIS database...
Best Regards,
Brent Fraser
On 11/29/2010 12:49 PM, Flavio Carmo wrote:
> Hi,
> Sorry, but i cant upload the shapes to postgres. The shapefiles are
> modified using arcview and the data in the postgres is modified using
> a custom desktop software that my client uses for about 5 years. The
> software open the shapefiles, then using a ODBC connection with
> postgres, make the join in memory and shows the information for each
> geometry.
> I cant undo this situation, so, my client propose to me to uses a
> opensource solution to also make this join in a WMS service. He knows
> Geoserver and Mapserver. Geoserver cant do this too, so i've hoped
> that mapserver could be a solution.
> Regards,
> Flávio Carmo
> On Mon, Nov 29, 2010 at 16:35, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
> On 11/29/2010 2:21 PM, flaviocarmo wrote:
> Hi,
> Thanks all for your responses. Im a novice in Mapserver so,
> after reading,
> now i know that:
> - I cant use a JOIN to shown only geometrys with the CODE
> field stored on
> Postgres (or another Database) because joins cannot modify the
> look of a
> map;
> - I need to use a template always to show the queries results;
> - Case-sensitive fields can be a problem in a query with
> mapserver;
> - The "PG:" string for was my mistake. I missed in the mail,
> but was in my
> MAP file. Sorry.
> Now what? There isnt a way to solve my issue? My client needs
> a opensource
> solution to deliver his data. His current solution (ESRI
> ArcGIS Server) is
> too expensive to buy another license, so he asked for a
> solution with the
> same quality, but opensource.
> There is a way to workaround this?
> Favlio,
> I would put all the data in a postgres/postgis database and
> display it from there. There is a simple shapefile loader:
> shp2pgsql. In this setup you can easily join tables, create
> inherited tables if you are working with data like streets.shp for
> multiple countries so the parent table can be used to seamlessly
> display the multiple streets tables as a single layer in mapserver.
> He may have to rethink his work flow a little because the tools
> are different, but this would be the case regardless if he is
> changing the software that he is using.
> -Steve W
> mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101129/1e272417/attachment.html
