[mapserver-users] WMS Request for a single point?
Robert Hicks
robhyx at gmail.com
Fri Oct 8 14:30:43 EDT 2010
Ok great! So that gave me an image with a push pin on it. So here is
another question: what is the bounding box of the requested image, and
can I specify it? I need to be able to merge this image together with
another GeoTiff (preferably using gdalmerge) so that the point lands
on the same geographic location in the base image. The original image
is in EPSG 4326, and I'm not sure what units of measurement this call
is using. I tried requesting the point layer as a tif but I think it
just gave me a regular non geotiff, which is fine because I can update
the header using gdal_translate but I need to know the bounding box in
4326.
On Fri, Oct 8, 2010 at 12:41 PM, Lime, Steve D (DNR)
<Steve.Lime at state.mn.us> wrote:
> I think you need:
> &mapsize=1000+500
> Or set it in the mapfile and mapserver will use that.
> Steve
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Robert Hicks
> Sent: Friday, October 08, 2010 11:40 AM
> To: Fawcett, David (MPCA)
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] WMS Request for a single point?
> Great, thanks for all the help everyone! I tried that command:
> http://10.0.11.54:8008/cgi-bin/mapserv.exe?map=/ms4w/apps/ms_ogc_workshop/client/wms/reference.map&mode=map&map_layer[0]=FEATURE+POINTS+270000+696000+END+END&WIDTH=1000&HEIGHT=500
> (I had to change a few things), and I get this error:
> "msDrawMap(): Image handling error. Unable to initialize image.
> msPrepareImage(): General error message. Image dimensions not
> specified. msCalculateScale(): General error message. Invalid image
> width or height. "
> Any ideas?
> On Fri, Oct 8, 2010 at 12:14 PM, Fawcett, David (MPCA)
> <David.Fawcett at state.mn.us> wrote:
>> This example works: http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/offset.map&mode=map&map_layer[0]=FEATURE+POINTS+270000+696000+END+END
>> You can access your layer through the layer name or it's (zero-based) index.
>> The simple example layer is below with a simple circle symbol defined in the map file.
>> LAYER
>> NAME 'singlepoint'
>> TYPE point
>> STATUS DEFAULT
>> CLASS
>> STYLE
>> COLOR 255 0 0
>> SIZE 15
>> symbol "circle"
>> END
>> END
>> END
>> SYMBOL
>> NAME "circle"
>> TYPE ellipse
>> FILLED true
>> POINTS
>> 1 1
>> END
>> END
>> Sent: Friday, October 08, 2010 11:07 AM
>> To: thomas bonfort
>> Ok, that looks extremely promising. I'm going to go ahead and try it
>> on my local Mapserver.
>> On Fri, Oct 8, 2010 at 12:03 PM, thomas bonfort
>> <thomas.bonfort at gmail.com> wrote:
>>> have a look at http://www.mail-archive.com/mapserver-users@lists.umn.edu/msg05881.html
>>> the syntax for cgi commands has changed since then, you'd have to use
>>> something like
>>> &map.layer[site]=feature+points+582248.23+4841497.11+end+end
>>> or &map.layer[site].feature.points=582248.23+4841497.11
>>> (I cant remember what syntax is correct)
>>> regards,
>>> thomas
>>> On Fri, Oct 8, 2010 at 17:10, Robert Hicks <robhyx at gmail.com> wrote:
>>>> Hello all! Ok, this is probably a long shot but, is there a way to
>>>> request an image from Mapserver that is just a point? The idea is I
>>>> have another larger (reference) map image and I want to place a push
>>>> pin on top of it in a specified point. It has to be a WMS call so that
>>>> I can take the image and merge it with the other larger map into one
>>>> so that it can be put into a PDF. Any help would be appreciated.
>>>> Thanks!
>>>> web http://www.hyxspace.com
>>>> aim hyx1138
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> aim hyx1138
> aim hyx1138
aim hyx1138
