Hi: [mapserver-users] MapServer as a reprojecting WMS proxy,is
it possible?
Niccolo Rigacci
niccolo at rigacci.org
Fri Oct 15 05:13:15 EDT 2010
On Wed, Oct 13, 2010 at 11:44:18PM +0300, Rahkonen Jukka wrote:
> > So I tried to configure MapServer to act as a proxy (both
> > client and server), doing the reprojection. But I failed.
> I can't test right now but I suppose this should work. Define
> the LAYER to use the SRS supported by the remote service like
> in the document http://mapserver.org/ogc/wms_client.html
Thanks, it works!
The recipe is:
* Declare the **target SRS** in MAP.PROJECTION and
MAP.METADATA.wms_srs
* Declare **only the source SRS** in MAP.LAYER.PROJECTION and
MAP.LAYER.PROJECTION.METADATA.wms_srs
* Declare the MAP.EXTENT, MAP.LAYER.EXTENT and
MAP.LAYER.METADATA.wms_extent using the correct SRS. This is
required to generate a GetCapabilities without warnings,
compatible with QGIS 1.5.0 too.
Here it is the actual mapfile (notes are in Italian only, sorry):
https://www.rigacci.org/wiki/doku.php/tecnica/gps_cartografia_gis/mapserver_wms_proxy
Niccolo Rigacci
Firenze - Italy
