[mapserver-users] Trouble shooting SLD?
K
ken at sandnarrows.com
Sun Oct 17 14:37:11 EDT 2010
Ok, didnt want to spam the the list, here is my map file and the SLD
file I am using:
MAP
NAME "Communities"
SIZE 700 500
UNITS meters
CONFIG PROJ_LIB "R:\proj\nad\"
CONFIG MS_ERRORFILE "mapserver.log"
DEBUG 5
EXTENT -12726256 6595213 -12674715 6655243
PROJECTION
"init=epsg:900913"
END
TRANSPARENT ON
IMAGECOLOR 255 255 255
IMAGEQUALITY 95
IMAGETYPE png
OUTPUTFORMAT
NAME png
DRIVER 'GD/PNG'
MIMETYPE 'image/png'
#IMAGEMODE PC256
EXTENSION 'png'
END
LEGEND
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
WEB
IMAGEPATH 'R:/webtemp/'
IMAGEURL '/webtemp/'
# WMS server settings
METADATA
'wms_title' '"Communities"'
'wms_onlineresource'
'http://someserver.com/cgi-bin/mapserv?map=wms.map&'
'wms_srs' 'EPSG:900913'
END
END
LAYER
NAME 'Communities'
TYPE POLYGON
DATA 'someshapefile.shp'
TEMPLATE 'ttt_query.html'
DUMP TRUE
METADATA
'wms_title' 'Communities'
'wms_include_items' 'ID'
END
STATUS DEFAULT
CLASS
NAME 'Communities'
STYLE
SYMBOL 'circle'
SIZE 3
OUTLINECOLOR 255 255 0
END
END
END
SYMBOL
NAME 'circle'
TYPE ELLIPSE
FILLED TRUE
POINTS 1 1 END
END
END
And the SLD file:
<StyledLayerDescriptor version="1.0.0">
<NamedLayer>
<Name>Communities</Name>
<UserStyle>
<Title>Communities</Title>
<FeatureTypeStyle>
<Rule>
<PolygonSymbolizer>
<Geometry>
<PropertyName>Communities</PropertyName>
</Geometry>
<Fill>
<CssParameter name="fill">#ff0000</CssParameter>
</Fill>
<Stroke>
<CssParameter name="stroke">#ff0000</CssParameter>
<CssParameter name="stroke-width">2.0</CssParameter>
</Stroke>
</PolygonSymbolizer>
</Rule>
</FeatureTypeStyle>
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
Thanks for your help,
Ken
On 17/10/2010 3:16 PM, Rahkonen Jukka wrote:
> Hi,
> It would be much easier to start thinking about what goes wrong if you could mail also your layer and the failing SLD.
> -Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: K
> Lähetetty: su 17.10.2010 21:09
> Vastaanottaja: Jeff McKenna
> Kopio: mapserver-users at lists.osgeo.org
> Aihe: Re: [mapserver-users] Trouble shooting SLD?
> Thanks, I tried one of those. Left colors as is, but changed the Name,
> Title and PropertyName fields to the name of the layer in my map file.
> Still no luck, just returns the normal map.
> Thanks again,
> Ken
> On 17/10/2010 11:57 AM, Jeff McKenna wrote:
>> On 10-10-17 11:01 AM, K wrote:
>>> Is there any way to trouble shoot why an SLD layer is being being
>>> rejected, or suggestions as to what it might be? Currently Mapserver
>>> seems to be ignoring the SLD and not displaying it, which I assume means
>>> some kind of parsing error or rejection of the SLD?
>>> I look at my getcapabilities and it says:<UserDefinedSymbolization
>>> SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>
>>> Which I assume means yes SLD is supported.
>>> I can browse to my SLD file, no errors opening it:
>>> http://www.rockies.ca/coyotes/sld_template2.xml
>>> I have tried using an SLD created by QGIS, one using PHP/Mapscript, and
>>> a couple from examples in Mapserver documentation that I edited to work
>>> for my use.
>>> I turned on the error log in my map file and put debug to 5, no mention
>>> of any errors or anything, though that isn't surprising as from what I
>>> read Mapserver currently catches those errors and displays the WMS layer
>>> as is, but provides no feedback as to the errors?
>>> I had spaces in my layer name to start, thought that might cause a
>>> problem so removed those.
>>> I have tried viewing in Openlayers, straight URL request, and via a
>>> quick mapscript application, all the same result.
>>> Any other suggestions?
>> Note that all SLDs used in the MapServer documentation can be accessed
>> at: http://demo.mapserver.org/ogc-demos/map/sld/
>> -jeff
