[mapserver-users] Problems with AGG rendering
Sharon Carter
carter.sharon017 at gmail.com
Mon Oct 25 13:21:38 EDT 2010
Hello,
We have been working with mapserver for a while and now we are updating our
map. We decided to give AGG a try for this new version but we have been
having some troubles setting it up to work properly.
When we moved from GD to AGG the map starting showing areas with different
colors than the ones specified in the map file.
Here we have an image with the rendering with GD
http://67.23.24.210/mapserver/gd.png
And one with AGG http://67.23.24.210/mapserver/agg.png
The output format for AGG we are using is
OUTPUTFORMAT
NAME 'PNG'
DRIVER AGG/PNG
IMAGEMODE RGBA
MIMETYPE "image/png;mode=24bit"
FORMATOPTION "FORMAT=image/png"
END
The street lines are painted using a symbol to create the outline for the
streets.
Any ideas what could be causing this?
Thanks
Sharon
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101025/1d9058d9/attachment.html
