[mapserver-users] question about joining
Mark Volz
MarkVolz at co.lyon.mn.us
Tue Oct 26 08:28:34 PDT 2010
Hello,
I have not used the Join shapefile to database function in mapserver before.
I just have a couple questions
* The description explains that "It is important to understand that
JOINs are ONLY available once a query has been processed. You cannot use
joins to affect the look of a map." Does that mean that we can only use the
joins for templates. If possible, I would like to label using a field in a
joined table.
* Is the following formatted correctly
#CLASSITEM 'PARC_CODE'
JOIN #TEST
NAME "MyJoin"
TABLE "LyonCounty/Parcels/test.dbf" #location of the
dbf file
FROM "PARCEL_ID" #shapefile field
TO "PIN" #dbf field
TYPE ONE-TO-ONE
END #JOIN
TEXT ("Name" * [MyJoin_MYNAME]) #label using the
joined table
Thanks
Mark Volz
GIS Specialist
Lyon County, MN
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101026/d5d7c8e6/attachment.htm>
More information about the MapServer-users
