[mapserver-users] Best Practices for the Spatial Index with Oracle	DB 11gR2
    Julian Wiersbitzki
    jw at hbt.de
    Wed Oct 27 02:51:30 PDT 2010
Hi List!
I am new here in this list and with mapserver, so please tell me if my question is already a faq.
We have mapserver 5.6.3 in use together with an Oracle DB 11gR2 Standard Edtion. All works well so far and configuring layer with the mapfile is no problem. But we have two layers which use SDO-Function in the SELECT Statement, e.g.:
   DATA "the_geom from (SELECT SDO_GEOM.SDO_CENTROID(geometrie, 2) AS the_geom, id FROM ereignis) USING SRID 31468"
or
   DATA "the_geom from (SELECT SDO_AGGR_UNION(SDOAGGRTYPE(the_geom, 0.005)) AS the_geom, bezirksinspektion AS label FROM stadtbezirk GROUP BY bezirksinspektion) USING SRID 31468"
If I want to fetch one of these layers the mapserver tells me there is no spatial index. Normally we have spatial indexes on all our tables with SDO_GEOMETRY columns, e.g.:
INSERT INTO user_sdo_geom_metadata VALUES (
  UPPER('ereignis'),
  UPPER('geometrie'),
  MDSYS.SDO_DIM_ARRAY(
    MDSYS.SDO_DIM_ELEMENT('X',4452550.887,4479484.083,0.001),
    MDSYS.SDO_DIM_ELEMENT('Y',5324953.397000001,5345694.052999999,0.001)),
    31468);
CREATE INDEX ereignis_geom_idx ON ereignis(geometrie) INDEXTYPE IS MDSYS.SPATIAL_INDEX;
But how do I create a spatial index on SDO-functions in the database? Can I even do that? The documentations only describes spatial index on SDO_GEOMETRY columns, but not on spatial functions.
What are the best practices for this kind of layers?
TIA, Julian
______________________________________________________________
Hamburger Berater Team GmbH       Handelsregister: HRB 31629
Stadthausbrücke 3 (Fleethof)      Amtsgericht Hamburg
20355 Hamburg                     Geschäftsführer:
Fon:  040/369779-43               Ilse Habermann
Fax:  040/369779-99               Hans-Joachim Habermann
Mail: mailto:jw at hbt.de          Daniel Hoffmann
Internet:                       http://www.hbt.de
http://www.geofox.de            http://www.geonetwatch.de
DIN EN ISO 9001:2000: DQS-Zertifikat Nr.5206 QM
Diese Email wurde mit ständig aktualisierten Virenscannern geprüft
Diese Email einschließlich eventuell angehängter Dateien
enthält vertrauliche Informationen und ist ausschließlich
für den bezeichneten Adressaten bestimmt. Wenn Sie nicht
der richtige Adressat oder dessen Vertreter sind, verständigen
Sie bitte sofort den Absender und löschen Sie dann diese Email
und eventuell angehängte Dateien. Vielen Dank!
Beachten Sie: Jede Form der Nutzung, Vervielfältigung oder
Weitergabe des Inhalts fehlgeleiteter Emails ist unzulässig.
This e-mail is intended only for the above addressee.
It may contain privileged information. If you are not the
addressee you must not copy, distribute, disclose or use any
of the information in it. If you have received it in error
please delete it and immediately notify the sender.
More information about the MapServer-users
