[mapserver-users] Maximum number of points in a poligon
Sebastian E. Ovide
sebastian.ovide at gmail.com
Wed Oct 27 09:20:54 EDT 2010
Do you spliited the polygons manually or you have some script ? perhaps
using gdal ?
On Wed, Oct 27, 2010 at 1:36 PM, Rahkonen Jukka
<Jukka.Rahkonen at mmmtike.fi>wrote:
> Hi,
> All I can say is that with our data the service went all to slow for the
> end users long before jamming. We have been splitting the biggest lake
> polygons into pieces with no more than 45000 vertises because that was the
> limit of reasonable speed in our environment. But in that case the limiting
> factor was the database and "contains" queries, not Mapserver. Anyhow,
> splitting the lakes was good for Mapserver too. For some other layers we
> have made simplified versions for the far-away zooms. Simplifying is better
> for WMS use if polygons are drawn with different outline colour but it gives
> a bit more work with building the scale dependent layers.
> -Jukka Rahkonen-
> *Lähettäjä:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *Puolesta *Sebastian E. Ovide
> *Lähetetty:* 27. lokakuuta 2010 14:57
> *Vastaanottaja:* mapserver-users at lists.osgeo.org
> *Aihe:* [mapserver-users] Maximum number of points in a poligon
> Hi All,
> I have a shape with 2M polygons. The biggest one has 13k points. It works
> very well, and fast enough.
> I have another shape with 300k polygons and the biggest one has 800k
> points... This shape hangs MapServer !... and I have to kill the process by
> hand using kill -9. (see the other thread: process survive after killing
> apache). The shape files can be opened with ogrinfo though
> Is there a maximum number of points for single polygon supported by
> MapServer ?
> Thanks
> Sebastian E. Ovide
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101027/1070b59b/attachment-0001.html
