[mapserver-users] Mapserver and projcs in geotiff header
Frank Warmerdam
warmerdam at pobox.com
Thu Oct 28 09:35:54 EDT 2010
Jørn Vegard Røsnes wrote:
> Hi all,
> just a feature check of Mapserver.
> Should Mapserver read the projection information in the geotiff header, if
> PROJECTION is not set in the LAYER def. of the map file?
> I'm testing with Mapserv 5.1-dev, and it's not working without PROJECTION,
> only when PROJECTION is set.
> I will soon try with a recent version of Mapserver (compiling).
Jørn,
MapServer does not ask the underlying data source for coordinate system
information by default. However, you can setup a projection block like:
PROJECTION
"auto"
END
to automatically read the projection through GDAL. This is a little
used feature, so it is possible it is broken now. The normal projection
block for your coordinate system would look something like:
PROJECTION
"+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +datum=WGS84 +units=m +no_defs"
END
If it is intended to be "google mercator" then you should use:
PROJECTION
"+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0
+k=1.0 +units=m +nadgrids=@null +no_defs"
END
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
