[mapserver-users] Display performance
Chris Jackson
webturtles at gmail.com
Fri Sep 3 05:12:35 EDT 2010
Hi Jukka
Thanks for the response and the great investigative work!
My log entry for drawing the layer is - [Fri Sep 03 10:01:25 2010].658000
msDrawMap(): Layer 1 (meanspringpeakflow), 24.500s. :o(
I do wonder if my Mapfile layer definition is just v.poor (admittedly no
expert!) so have taken an excerpt of the layer defintion (there are about 15
classes in all) - views anyone, should I be loading it a different way?
Also Jukka, could I get a sample of your scale dependent WMS GROUP layer map
code - as it sounds like a great idea maybe for this but also some v.hi-res
model grids I am thinking about.
Thanks again, much appreciated!
Chris
LAYER
NAME "meanspringpeakflow"
TYPE polygon
DEBUG 5
DATA "Tide"
TEMPLATE void
PROJECTION
"+proj=utm +zone=31 +ellps=GRS80 +units=m +no_defs"
END
METADATA
"DESCRIPTION" "Mean Spring Peak Flow"
"RESULT_FIELDS" "ID,DISTANCE,DEPTH,MEAN_SP_PC"
"RESULT_HEADERS" "ID,Minimum Distance (m),Average Depth (m),Mean Spring
Peak Flow (m/s)"
"ows_title" "meanspringpeakflow"
"RESULT_HYPERLINK" "ID|| Load graphing tool"
END # Metadata
CLASS
NAME '> 4.00 (m/s) '
EXPRESSION ([MEAN_SP_PC] >= 4 AND [MEAN_SP_PC] < 4.5)
STYLE
COLOR 135 99 64
END #end style
END # end class
CLASS
NAME '3.51 - 4.00'
EXPRESSION ([MEAN_SP_PC] >= 3.5 AND [MEAN_SP_PC] < 4)
STYLE
COLOR 158 126 63
END #end style
END # end class
etc etc
On 3 September 2010 09:04, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
> I took some numbers to compare with.
> Material and methods
> Polygon layer, rather simple polygons with few vertises, Feature Count:
> 117383
> DEBUG 5 in mapfile
> WMS client asks for the whole layer
> Mapserver 5.2.1 (CGI) on not so fast Windows computer
> Results
> First request: rendering time taken from the log file are between 3.5 and
> 4.5 seconds
> Following request, BBOX is changing but all the polygons are drawn though:
> rendering times 1.5 - 2.5 seconds
> Conclusions and discussion
> At first one might think that my server is faster. But this test is not
> controlled at all because we are not using the same shapefiles and we can't
> say so. What we can say that a couple of hundred of thousand polygons can be
> drawn faster.
> However, it does not really make sense to render an image this way if it
> should be fast. If the screen has 1000 by 1000 pixels it makes a million
> pixels together. For 200000 polygons it makes 5 pixels per polygon. You
> can simplify your polygon geometries pretty much before anybody can see the
> differense. If the polygons are spread evenly nobody can even see the
> difference if there are 20000 or 200000 polygons on the screen.
> We have one polygon layer with about million polygons and for that I made
> two simplified layers which contain only 1 percent and 10 percent of all the
> polygons. Those and the original shapefile are put into the same scale
> dependent WMS GROUP layer. This group is pretty fast at any scale. The 1
> percent layer is perhaps a bit too sparse but I have been too lazy to have a
> try with 2 or 5 percent samples.
> -Jukka Rahkonen-
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100903/dc78abe1/attachment.html
