[mapserver-users] Artifacts on raster dataset after using gdaladdo
Dejan Gambin
dejan.gambin at coin.hr
Fri Sep 3 05:31:14 EDT 2010
I have a set of aerial ortophoto images. I have done the following:
1. gdal_translate -co "TILED=YES" on all of them
2. gdaladdo 2 4 8 16 on all of them
3. gdaltindex
The problem is - artifacts appear in the lower right corner of each raster file (tiled and overviewed). They ave different colors depending of the scale. For example, on 1:15000 scale they appear as yellow squares. On 1:10000 scale they appear as blue _| (reverse "L"). On 1:5000 they disappear
I investigated and found out this happens after using gdaladdo. I am using gdaladdo from gdal-bin on 64bit debian. The version of gdal-bin is 1.5.2-3. I saw similar issues reported in ticket #2346 2 years ago. Should I use newer GDAL library?
regards, dejan
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100903/57ba8225/attachment.html
