[mapserver-users] Display performance
thomas bonfort
thomas.bonfort at gmail.com
Fri Sep 3 06:12:12 EDT 2010
On Fri, Sep 3, 2010 at 11:12, Chris Jackson <webturtles at gmail.com> wrote:
> Hi Jukka
> Thanks for the response and the great investigative work!
> My log entry for drawing the layer is - [Fri Sep 03 10:01:25 2010].658000
> msDrawMap(): Layer 1 (meanspringpeakflow), 24.500s. :o(
> I do wonder if my Mapfile layer definition is just v.poor (admittedly no
> expert!) so have taken an excerpt of the layer defintion (there are about 15
> classes in all) - views anyone, should I be loading it a different way?
> Also Jukka, could I get a sample of your scale dependent WMS GROUP layer map
> code - as it sounds like a great idea maybe for this but also some v.hi-res
> model grids I am thinking about.
> Thanks again, much appreciated!
> Chris
> LAYER
> NAME "meanspringpeakflow"
> TYPE polygon
> DEBUG 5
> DATA "Tide"
> TEMPLATE void
> PROJECTION
> "+proj=utm +zone=31 +ellps=GRS80 +units=m +no_defs"
> END
> METADATA
> "DESCRIPTION" "Mean Spring Peak Flow"
> "RESULT_FIELDS" "ID,DISTANCE,DEPTH,MEAN_SP_PC"
> "RESULT_HEADERS" "ID,Minimum Distance (m),Average Depth (m),Mean Spring
> Peak Flow (m/s)"
> "ows_title" "meanspringpeakflow"
> "RESULT_HYPERLINK" "ID|| Load graphing tool"
> END # Metadata
> CLASS
> NAME '> 4.00 (m/s) '
> EXPRESSION ([MEAN_SP_PC] >= 4 AND [MEAN_SP_PC] < 4.5)
> STYLE
> COLOR 135 99 64
> END #end style
> END # end class
> CLASS
> NAME '3.51 - 4.00'
> EXPRESSION ([MEAN_SP_PC] >= 3.5 AND [MEAN_SP_PC] < 4)
> STYLE
> COLOR 158 126 63
> END #end style
> END # end class
> etc etc
you can speed things up a little by simplifying your expressions in
case mean_sp_pc is a continous value:
class
expression ([item]>=4)
end
class
expression ([item]>=3.5) #this suffices and implies [item] <4 as
all entries with [item]>=4 wil have been treated by the first class
end
class
...etc...
end
regards,
thomas
> On 3 September 2010 09:04, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
>> Hi,
>> I took some numbers to compare with.
>> Material and methods
>> Polygon layer, rather simple polygons with few vertises, Feature Count:
>> 117383
>> DEBUG 5 in mapfile
>> WMS client asks for the whole layer
>> Mapserver 5.2.1 (CGI) on not so fast Windows computer
>> Results
>> First request: rendering time taken from the log file are between 3.5 and
>> 4.5 seconds
>> Following request, BBOX is changing but all the polygons are drawn
>> though: rendering times 1.5 - 2.5 seconds
>> Conclusions and discussion
>> At first one might think that my server is faster. But this test is not
>> controlled at all because we are not using the same shapefiles and we can't
>> say so. What we can say that a couple of hundred of thousand polygons can be
>> drawn faster.
>> However, it does not really make sense to render an image this way if it
>> should be fast. If the screen has 1000 by 1000 pixels it makes a million
>> pixels together. For 200000 polygons it makes 5 pixels per polygon. You
>> can simplify your polygon geometries pretty much before anybody can see the
>> differense. If the polygons are spread evenly nobody can even see the
>> difference if there are 20000 or 200000 polygons on the screen.
>> We have one polygon layer with about million polygons and for that I made
>> two simplified layers which contain only 1 percent and 10 percent of all the
>> polygons. Those and the original shapefile are put into the same scale
>> dependent WMS GROUP layer. This group is pretty fast at any scale. The 1
>> percent layer is perhaps a bit too sparse but I have been too lazy to have a
>> try with 2 or 5 percent samples.
>> -Jukka Rahkonen-
> mapserver-users at lists.osgeo.org
