[mapserver-users] Re: Raster Layer Error
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Sep 6 09:37:55 EDT 2010
Have you checked:
ls -la /var/www/Turkiye.jp2
ls -la /var/www
And made sure that this are accessible by apache?
What does: .../cgi-bin/mapserv -v report?
-Steve W
On 9/6/2010 7:55 AM, Ibrahim Saricicek wrote:
> Hi..
> No it's not about the path, I've tried shapepath either.
> On Mon, Sep 6, 2010 at 12:23 PM, Sumit Sharma [via OSGeo.org] <[hidden
> email] </user/SendEmail.jtp?type=node&node=5502902&i=0>> wrote:
> I would suggest you to revisit your path, try using shapepath,
> imagepath etc. and make sure that you are able to refer your files
> properly.
> You may also like to carefully observe permissions on your server.
> Try to see mapserver debug info by setting debug level 5, that may
> also give you some more information about your problem.
> -Sumit
> View message @
> http://osgeo-org.1803224.n2.nabble.com/Raster-Layer-Error-tp5502458p5502593.html
> <http://osgeo-org.1803224.n2.nabble.com/Raster-Layer-Error-tp5502458p5502593.html?by-user=t>
> To unsubscribe from Raster Layer Error, click here
> <http://osgeo-org.1803224.n2.nabble.com/template/TplServlet.jtp?tpl=unsubscribe_by_code&node=5502458&code=aWJyYWhpbXNhcmljaWNla0BnbWFpbC5jb218NTUwMjQ1OHwtMTMzMTA0MzIxNQ==&by-user=t>.
> Hi Hi All,
> A 800Mb Jpeg2000 file works on MS4W, but returns an error on Linux.
> What is meant on the error message?
> *The error message is;*
> <ServiceException>
> msDrawMap(): Image handling error. Failed to draw layer named 'Uydu'.
> GetBlockRef failed at X block offset 267, Y block offset 96: Unable to
> access file. GDALRasterIO() failed: drawGDAL()
> </ServiceException>
> *This is layer definition;*
> LAYER
> NAME 'Uydu'
> DATA "/var/www/Turkiye.jp2"
> TYPE RASTER
> PROJECTION
> "init=epsg:4326"
> END
> STATUS ON
> END
> This is Window 7 side;*
> version 5.4.0-rc2 Libs;
> curl-7.15.1
> expat-2.0.1
> fcgi-2.4.0
> fits-3.0.2
> freetype-2.1.10
> fribidi-0.19.1
> gd-2.0.35
> gdal-1.6.0 RC2
> geos-2.2.3
> gettext-0.13
> hdf5
> jbigkit-1.6
> jpeg-6b
> libecwj2-3.3
> libgeotiff-1.2.3
> libiconv-1.9.1
> libintl-0.11.5
> libpng-1.2.8
> libxml2-2.6.23.win32
> mapserver-5.2.1
> ming-0.2a
> mrsid-6.0.7.1407
> mysql-5.0.18-win32
> netcdf-3.6.1
> PDFlib-Lite-6.0.2
> php-5.2.6
> postgresql-8.3.3
> proj-4.6.1
> Python-2.5.1
> regex-0.12
> sqlite3
> SWIG-1.3.33
> tiff-cvs (02/04/08)
> xerces-c-2.7.0
> zlib-1.2.3
> *This is Debian Lenny 64-bit server side;*
> version 5.4.2 libs;
> Mapserv 5.4.2
> -lgd -L/usr/lib64 -lgd -ljpeg -lfreetype -lz -lpng -lz -lXpm -lX11
> -L/usr/local/src/agg-2.4//src -lagg -ltiff -ljpeg -lfreetype -lz -lpng
> -lz -lXpm -lX11 -lproj -ljpeg -lpng -L/usr/local/lib -lgdal -L/usr/lib
> -lgeos_c -L/usr/lib -lsqlite3 -lodbc -lodbcinst -L/usr/lib -lexpat
> -L/usr/lib -lxerces-c -lpthread -ljasper -lhdf5 -lmfhdf -ldf -lgif
> -ljpeg -ltiff -lpng -lnetcdf -lpq -L/usr/lib -lpq -lz -lm -lrt -ldl
> -lcurl -L/usr/lib -lpq -L/usr/lib/mysql -lmysqlclient -lmysqlclient
> -lcurl -L/usr/lib -lgeos_c -lpthread -L -lc -lz -lxml2 -lm -lstdc++
> Gd-2.0.35
> Gdal 1.7.2
> ./configure --with-png --with-jpeg --with-gif --with-jasper=/usr/local
> JasPer support: yes (GeoJP2=yes)
> jasper-1.900.1.uuid
> ./configure
> View this message in context: Re: Raster Layer Error
> <http://osgeo-org.1803224.n2.nabble.com/Raster-Layer-Error-tp5502458p5502902.html>
> Sent from the Mapserver - User mailing list archive
> <http://osgeo-org.1803224.n2.nabble.com/Mapserver-User-f1969211.html> at
> Nabble.com.
> mapserver-users at lists.osgeo.org
