[mapserver-users] MapServer and MapScript in separate hosts
Wim Vanbelle
wimvanbelle at gmail.com
Tue Sep 7 05:07:26 EDT 2010
If you compile mapserver from source, you can use ./configure
--prefix=/path/to/executable to install it in the folder you want.
You do need to make sure that LD can find the shared libraries. This should
then be set in apache config so that the right environment paths are loaded.
As for the external URL thing. Just configure a CGI script at a given URL
(as configured in your webserver) and then point to the location of your
mapserv executable.
Perhaps this is what you are looking for:
http://mapserver.org/cgi/wrapper.html
2010/9/7 Román González <rgonzalez at normagricola.com>
> Hello:
> Maybe it’s a silly question but I’d like to know if I can use MapScript in
> a web server with PHP being MapServer installed in a different host. All the
> examples I’ve seen seem to run in the same server and I can’t find a way to
> set up an URL for the MapServer location.
> Thank you.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100907/d814a5c8/attachment.html
