[mapserver-users] Split Polygon using Clint or server side code
not with PostGIS
venkat
ven.tammineni at gmail.com
Tue Sep 7 06:46:01 EDT 2010
Dear Josh,
Thanks for your great response.Yes You done my work around... Thanks
alot..Let me work on that...i will update you once i done ...
Thanks again.
Ven
On Tue, Sep 7, 2010 at 4:11 PM, Joshua Hevenor <jhevenor at rogers.com> wrote:
> Ven,
> First, I took a quick look at the php mapscript documentation (my
> preferred mapscript) and didn't see anything specific about splitting.
> Solving a more simplified problem might be a start.
> Start by getting the bounding box of the polygon ($shp->bounds).
> Get the two left side coordinates: $p1=(MinX, MaxY), $p2=(MinX, MinY)
> Build a new polygon using these two points and the endpoints of your line.
> --> Assumption that your line is not horizontal or intersects the left edge
> of your bbox.
> Use the shapeObj::intersection to get the half of your target polygon
> within the left half of the BBOX.
> You can repeat this for the right half of the BBOX, or maybe use
> shapeObj::difference.
> My first thoughts.
> You could, alternatively, loop through all of
> $shp->lines(1..$shp->numlines) and checking for intersection with your split
> line. A little bookkeeping would allow you to build your two split polygons
> from this. I think option 1 might be easier.
> Hope this helps,
> Josh
> --- On *Tue, 9/7/10, venkat <ven.tammineni at gmail.com>* wrote:
> From: venkat <ven.tammineni at gmail.com>
> Subject: [mapserver-users] Split Polygon using Clint or server side code
> not with PostGIS
> To: mapserver-users-request at lists.osgeo.org,
> mapserver-users at lists.osgeo.org
> Date: Tuesday, September 7, 2010, 1:46 AM
> Dear All,
> How i can split polygon by client(JavaScript code) or Server side(C#).I
> have done splitting polygon using Postgis..I am not able to understand how
> to split polygon by code(client or server side code.Please let me know .Its
> very urgent.
> I am waiting for your great response.
> Thanks and Regards,
> Ven
> -----Inline Attachment Follows-----
> mapserver-users at lists.osgeo.org<http://mc/compose?to=mapserver-users@lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100907/f59c89eb/attachment.html
