[mapserver-users] How to apply WFS filters for PostGIS hstore data?
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Sep 10 05:30:09 EDT 2010
Got INSPIREd at FOSS4G and desided to have a try with paleogissic
WMS and WFS services with OpenStreetMess (OSM) data.
I imported an OSM excerpt of Finland with osm2pgsql utility by using the
-k switch
for storing all the OSM tags and values into PostGIS. They got all
dumped into
one singe column "tags" which is of datatype "hstore"
http://www.postgresql.org/docs/8.4/static/hstore.html
<http://www.postgresql.org/docs/8.4/static/hstore.html>
Then I created a few simple layers by querying tags and values from the
hstore.
See an example of layer definitions from the bottom of this message
Now it is possible to try how WMS behaves with hstore. By editing the
"tag" and "value" keys
it is possible to get what ever map you like. I will try to keep my
demo service online
at least for a week for testing.
A supermarketmap
http://188.64.1.61/cgi-bin/mapserv?map=/usr/map/osm-mapserver_i.map&REQU
EST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDTH=1059&HEIGHT=687&LAYERS=sea,bo
rders,POI_free_query&TRANSPARENT=TRUE&FORMAT=image%2Fpng&BBOX=-574187,65
58020,1615375,7978444&SRS=EPSG:3067&STYLES=&tag=shop&value=supermarket
A fuelstationmap
58020,1615375,7978444&SRS=EPSG:3067&STYLES=&tag=amenity&value=fuel
Hstore query works also with lines and polygons:
A maxspeedmap (fixed, only maxspeed value is selectable)
rders,maxspeed_query&TRANSPARENT=TRUE&FORMAT=image%2Fpng&BBOX=-574187,65
58020,1615375,7978444&SRS=EPSG:3067&STYLES=&maxspeed=100
<http://188.64.1.61/cgi-bin/mapserv?map=/usr/map/osm-mapserver_i.map&REQ
UEST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDTH=1059&HEIGHT=687&LAYERS=sea,b
orders,maxspeed_query&TRANSPARENT=TRUE&FORMAT=image%2Fpng&BBOX=-574187,6
558020,1615375,7978444&SRS=EPSG:3067&STYLES=&maxspeed=100>
Then gml output from WFS, "Get 10 toilets"
http://188.64.1.61/cgi-bin/mapserv?map=/usr/map/osm-mapserver_i.map&serv
ice=wfs&version=1.1.0&request=getfeature&typename=POI_free_query&maxfeat
ures=10&tag=amenity&value=toilets
<http://188.64.1.61/cgi-bin/mapserv?map=/usr/map/osm-mapserver_i.map&ser
vice=wfs&version=1.1.0&request=getfeature&typename=POI_free_query&maxfea
tures=10&tag=amenity&value=toilets>
or "Get 100 restaurants"
ures=100&tag=amenity&value=restaurant
If the service is up you will see that WFS is sending all the tags as a
one string, like this:
<ms:tags>
"name"=>"Fantasia", "amenity"=>"restaurant", "cuisine"=>"pizza",
"wheelchair"=>"yes", "opening_hours"=>"Mo-Fr 10:30-19:30; Sa
12:00-19:30; Su 13:00-19:30"
</ms:tags>
So both the WMS (including getFeatureInfo) and WFS are working very nice
if the query is done by sending
extra parameters with the getMap or getFeature requests. However, that
is not especially standard way
to do queries. Thus this is my question:
Is is somehow possible to do selections from the hstore backend by using
WFS attribute filters?
There is an unfiltered feature type "tagsoup" available in my WFS
service
ice=wfs&version=1.1.0&request=getfeature&typename=tagsoup&maxfeatures=10
vice=wfs&version=1.1.0&request=getfeature&typename=tagsoup&maxfeatures=1
0>
If someone gets interested in trying to apply WFS filters for this
feature type, just go ahead and tell if they work.
LAYER
TYPE POINT
STATUS ON
PROJECTION
"init=epsg:3067"
#UTM because Web Mercator makes Finland ugly
END
NAME "POI_free_query"
INCLUDE "/usr/map/connection.map"
DATA "way from (select (way),osm_id,tags from osm_point where (tags
@>'%tag%=>%value%')) as foo using unique osm_id using srid=3067"
# I feel that more recent MapServer versions demands validation
METADATA
"wfs_title" "free_tag_query"
"gml_featureid" "osm_id"
"gml_include_items" "osm_id,tags"
END
DUMP TRUE
#DEBUG 5
TEMPLATE "/usr/templates/mstemplate.html"
CLASS
STYLE
SIZE 10
SYMBOL "citycircle"
COLOR "#FF6767"
OUTLINECOLOR 0 0 0
END
STYLE
SIZE 2
SYMBOL "citycircle"
COLOR "#000000"
END
END
END
-Jukka Rahkonen-
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100910/34789621/attachment.html
