[mapserver-users] Error in msPostGISLayerResultsGetShape(): Got
request larger than result set
Stefan Neumeier
stefan.neumeier at vti.bund.de
Thu Sep 16 07:09:00 EDT 2010
Dear all,
I am quite new to mapserver and maybe I am just missing some important configuration step but I hope somebody
of you can help me with following problem:
When trying to perform a query via a cartoweb-client to a layer stored in Postgis I encounter following error message
(It is only the query that is not working the layer itself renders perfect out of the database):
MapServer error: Error in msDrawMap(): Failed to draw layer named 'bound'.
Error in msPostGISLayerResultsGetShape(): Got request larger than result set.
When I do the same with the layer as shapefile on the file system the query functions as expected.
*My system environment is:*
cartoweb 3.5.0
php 5.3.3
Mapserver version 5.6.5
Postgis 1.5.1
Postgresql 8.4.4
Operating System: Suse Linux 11.3
*In the mapfile the layer is defined as follows*
LAYER
NAME "bound"
TYPE LINE
STATUS ON
CONNECTIONTYPE POSTGIS
CONNECTION "user=*** password=*** host=localhost dbname=gis"
DATA "the_geom FROM (select * from dep_france_dom) as foo using unique gid using srid=-1"
TEMPLATE "ttt"
METADATA
"id_attribute_string" "id_geofla"
"query_returned_attributes" "id_geofla"
END
CLASS
NAME "Boundaries"
STYLE
COLOR 200 200 200
OUTLINECOLOR 255 165 96
END
END
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100916/f543ff8e/attachment.html
