[mapserver-users] Could not read data from MySQL database
Murat Beyhan
beyhan at deprem.gov.tr
Thu Sep 16 18:17:54 EDT 2010
Dear Friends,
I was succeeded to read and draw data from MySQL database using OGR
connection until upgrade mapserver and gdal.
Now I use the same codes but could not read data form MySql database.
I have created tables using ogr2ogr again.
but still When I open webpage the following error message occurred.
msDrawMap(): Image handling error. Failed to draw layer named 'sea'.
msOGRFileOpen(): OGR error. Open failed for OGR connection in layer
`sea'. File not found or unsupported format.
What is wrong for that, please help.
When I try ogrinfo as follows it works
[murat at localhost mapdata]$ ogrinfo
"MySQL:testogr,user=root,password=mysql_123"
INFO: Open of `MySQL:testogr,user=root,password=mysql_pass'
using driver `MySQL' successful.
1: deniz (Polygon)
2: il_merkezleri (Point)
3: il_sinirlari (Polygon)
4: ilce_merkezleri (Point)
5: ilce_sinirlari (Polygon)
6: iller (Polygon)
7: iller_sil (Polygon)
8: komsular (Polygon)
AND
my mapserver version info as follows
[murat at localhost mapdata]$ mapserv -v
MapServer version 5.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS
INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
and
--formats
Supported
Formats:
-> "ESRI
Shapefile" (read/write)
-> "MapInfo
File" (read/write)
"UK .NTF" (readonly)
-> "SDTS" (readonly)
-> "TIGER" (read/write)
-> "S57" (read/write)
-> "DGN" (read/write)
-> "VRT" (readonly)
-> "REC" (readonly)
-> "Memory" (read/write)
-> "BNA" (read/write)
-> "CSV" (read/write)
-> "GML" (read/write)
-> "GPX" (read/write)
-> "KML" (read/write)
-> "GeoJSON" (read/write)
-> "Interlis 1" (read/write)
-> "Interlis 2" (read/write)
-> "GMT" (read/write)
-> "SQLite" (read/write)
-> "ODBC" (read/write)
-> "PGeo" (readonly)
-> "OGDI" (readonly)
-> "MySQL" (read/write)
-> "PCIDSK" (readonly)
-> "XPlane" (readonly)
-> "AVCBin" (readonly)
-> "AVCE00" (readonly)
-> "DXF" (read/write)
-> "GRASS" (readonly)
-> "Geoconcept" (read/write)
-> "GeoRSS" (read/write)
-> "GPSTrackMaker" (read/write)
-> "VFK" (readonly)
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
