[mapserver-users] RE: CGI returning a 502 error
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Thu Sep 23 13:14:38 EDT 2010
Nope, can't combine those. At least you can specify symbol/size/color all at once...
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of stoli
Sent: Thursday, September 23, 2010 10:47 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] RE: CGI returning a 502 error
Thanks Steve. Looks like I am going to have to figure out how to compile my
own binaries. I think I have streamlined the POST parameters as much as I
can, unless there is a way to combine the following:
&map_layer[layer1]=FEATURE+POINTS+0+0+END+END
&map_layer[layer1]_CLASS[0]_STYLE[0]=SYMBOL+ellipse+SIZE+200+COLOR+255+0+0
Lime, Steve D (DNR) wrote:
> Yes, there is a preset limit on the number of parameters the MapServer cgi
> will accept and indeed it is 100. There are two ways to work around this.
> 1) Edit the MS_MAX_CGI_PARAMS setting in cgiutil.h and recompile.
> 2) Consider combining the requested layers calls into a single variable.
> That is:
> Change
> ...layer=layer1&layer=layer2&layer=layer3...
> to:
> ...layers=layer1+layer2+layer3...
> You should see an error message from MapServer in your web server error
> log if you ran into this limitation...
> Steve
> Sent: Tuesday, September 21, 2010 11:19 AM
> I do not think it is a string length limit. The IIS returns a separate
> error
> for that. At least it does when you exceed the URL length limit in a GET
> request.
> I have been doing some tests and it looks like it might be more of a limit
> in the number of parameters in the POST request. I can't find any info
> regarding the maximum number of parameters that you can send in one
> request
> (to an IIS server), but again, I would think that IIS would be responding
> with a more specific error if the limit was with it.
> Is it possible that the MapServer CGI is limited to 100 POST parameters?
> Fawcett, David (MPCA) wrote:
>> According to the docs, starting with MapServer 5.0, there is no limit to
>> the number of layers in a mapfile.
>> http://mapserver.org/introduction.html#layer-object
>> I am guessing that you are running into a different issue.
>> Have you captured the post request string and examined it to make sure
>> that it is valid?
>> Are you running into a string length limit for your post request? The
>> URL
>> for your post request would be limited to ~2k char for IE, but this only
>> includes the URL to the server, not the key:value pairs. There could be
>> a
>> size limit for post requests set on your Web server to help prevent DOS
>> attacks. I don't know where this would be set in IIS.
>> David.
>> Sent: Monday, September 20, 2010 6:18 PM
>> Subject: [mapserver-users] CGI returning a 502 error
>> I'm using the ms4w binaries (5.6.3) under IIS 7.
>> My application sends (via http POST) a lot of parameters to modify the
>> .map
>> file. Mostly to add features to layers that are turned off by default and
>> then make them visible. When my parameters cause the map to show over 50
>> layers, the IIS returns a 502 error.
>> I realize that the max layers are set to 100 in the default map.h file,
>> but
>> like I said, I am using the compiled binaries from ms4w. Does anyone know
>> if
>> they change that to 50 when they compile, or should I look elsewhere to
>> find
>> my problem?
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/CGI-returning-a-502-error-tp5552675p5552675.html
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> http://osgeo-org.1803224.n2.nabble.com/CGI-returning-a-502-error-tp5552675p5555339.html
View this message in context: http://osgeo-org.1803224.n2.nabble.com/CGI-returning-a-502-error-tp5552675p5563549.html
