[mapserver-users] Error in msPostGISLayerResultsGetShape(): Got
request larger than result set
Daniel Morissette
dmorissette at mapgears.com
Fri Sep 24 07:19:12 EDT 2010
Presumably this is related to the change in the way query results are
handled in MapServer 5.6.5 and the Cartoweb code would need to be
updated to use $layer->resultsGetShape() instead of $layer->getShape()
to read query results.
Another option would be for you to go back to MapServer 5.4.x
Daniel
Stefan Neumeier wrote:
> Dear all,
> I am quite new to mapserver and maybe I am just missing some important configuration step but I hope somebody
> of you can help me with following problem:
> When trying to perform a query via a cartoweb-client to a layer stored in Postgis I encounter following error message
> (It is only the query that is not working the layer itself renders perfect out of the database):
> MapServer error: Error in msDrawMap(): Failed to draw layer named 'bound'.
> Error in msPostGISLayerResultsGetShape(): Got request larger than result set.
> When I do the same with the layer as shapefile on the file system the query functions as expected.
> *My system environment is:*
> cartoweb 3.5.0
> php 5.3.3
> Mapserver version 5.6.5
> Postgis 1.5.1
> Postgresql 8.4.4
> Operating System: Suse Linux 11.3
> *In the mapfile the layer is defined as follows*
> LAYER
> NAME "bound"
> TYPE LINE
> STATUS ON
> CONNECTIONTYPE POSTGIS
> CONNECTION "user=*** password=*** host=localhost dbname=gis"
> DATA "the_geom FROM (select * from dep_france_dom) as foo using unique gid using srid=-1"
> TEMPLATE "ttt"
> METADATA
> "id_attribute_string" "id_geofla"
> "query_returned_attributes" "id_geofla"
> END
> CLASS
> NAME "Boundaries"
> STYLE
> COLOR 200 200 200
> OUTLINECOLOR 255 165 96
> END
> END
> END
> mapserver-users at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
