[mapserver-users] Expressions
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Sep 29 13:50:49 EDT 2010
First lets get rid of the parameter substitution to make sure we have a
syntax correct. So in your mapfile try:
EXPRESSION ([IncidentDa] > 20100816)
I set this to Aug 16th to see if you can pull any records. Also because
this is numeric, I removed the quotes. You can also try it with quotes
to see what works.
If this works then try:
EXPRESSION ([IncidentDa] > %LASTTWOWEEKS%)
Again without the quotes or with depending on what worked.
-Steve W
On 9/29/2010 11:49 AM, Jay Kapalczynski wrote:
> I thank you for your response....greatly appreciated as I cannot figure
> this out....
> I know that I have 4 features in the dataset that have a value of
> 20100916 that’s 13 days ago....so with the expression below those 4 or 5
> features should show up....but nothing shows up
> IncidentDa is the field (long integer)
> Param type is specifying YYYYMMDD my data has values of 20100916 (13 days)
> I have no idea what could be wrong…Thank you all for your help….
> *.XML file*
> <map-source name="Burglaries" type="mapserver">
> <file>./maple_grove_datasets/police/Burglaries.map</file>
> <param type="today" offset="-90" name="LASTNINTY" format="%4Y%2M%2D" />
> <param type="today" offset="-30" name="LASTTHIRTY" format="%4Y%2M%2D" />
> * <param type="today" offset="-14" name="LASTTWOWEEKS"
> format="%4Y%2M%2D" />*
> * <param type="today" offset="-7" name="LASTWEEK" format="%4Y%2M%2D" />*
> <param type="today" offset="0" name="TODAY" format="%4Y%2M%2D" />
> <layer name="Burglaries"/>
> </map-source>
> *.MAP file*
> CLASS
> NAME 'Last Weeks'
> EXPRESSION ('[IncidentDa]' > '%LASTTWOWEEKS%' && '[IncidentDa]' <
> '%LASTWEEK%')
> STYLE
> COLOR 0 100 50
> SYMBOL "bike"
> SIZE 12
> END
> END
> BUT if I simply place this in there I get all the points…so something is
> weird here because most of the dates are older than 7 days.
> CLASS
> NAME 'Last Weeks'
> EXPRESSION ('[IncidentDa]' > '%LASTWEEK%’)
> STYLE
> COLOR 0 0 0
> SYMBOL "tent"
> SIZE 12
> END
> #END
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen
> Woodbridge
> Sent: Wednesday, September 29, 2010 8:19 AM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Expressions
> In EXPRESSIONS you can evaluate any of the following:
> 1. Regular expressions treating the value as a string
> 2. numeric expressions using booleans like ==,<,>,<=,>=
> 3. string expressions like ==, !=, and I think strlen()
> So if you converted you dates into a format like YYYYMMDD then it would
> be easy to use a numeric expression like:
> EXPRESSION ('[dateValues]' > '%STARTDATE%' && '[dateValues]' < '%ENDDATE%')
> or
> EXPRESSION ('[dateValues]' > '%STARTDATE%')
> where STARTDATE is the YYYYMMDD value of two weeks ago and ENDDATE would
> be in the same format and allow you to extract record betwee any two
> start and end dates.
> Or you might be able to figure out a complex regular expression the
> represents the last two weeks like:
> EXPRESSION ('[dateValues]' =~ '/%LASTTWOWEEKS%/')
> I'm not sure what you would need for the regular expression.
> -Steve W
> On 9/28/2010 4:23 PM, Jay Kapalczynski wrote:
> > Anyone have anymore ideas about this….
> > I have a string field with values
> > And the code below. The expression does not seem to be running…if I only
> > use LASTTWOWEEKS it still draws all the points….and I know there are
> > values in there from 2008
> > Thanks
> > *From:* mapserver-users-bounces at lists.osgeo.org
> > [mailto:mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Jay
> > Kapalczynski
> > *Sent:* Tuesday, September 21, 2010 9:51 AM
> > *To:* 'Bob Basques'; mapserver-users at lists.osgeo.org
> > *Subject:* RE: [mapserver-users] Expressions
> > My major question is can I do this with a String/text field? Its the
> > only way I can see keeping things in a %2Y%2M%2D format ex. 092110 (Sept
> > 21^st 2010), otherwise the 0 will get removed in a numeric field
> > Can I use the format Year, Month, Day? Or do I have to use Month,
> Day, Year?
> > In this example I eliminated two expressions and focused on one
> > Expression to see if it is working.
> > *_I kept this_*
> > <param type="today" offset="-7" name="LASTWEEK" format="%2Y%2M%2D" />
> > <param type="today" offset="-30" name="LASTTHIRTY" format="%2Y%2M%2D" />
> > <param type="today" offset="-90" name="LASTNINTY" format="%2Y%2M%2D" />
> > </map-source>
> > *_In my map file I used _**_ONLY_**_ this_*
> > CLASS
> > NAME 'Last Weeks'
> > EXPRESSION ('[dateValues]' > '%LASTTWOWEEKS%')
> > STYLE
> > COLOR 0 100 50
> > SYMBOL "bike"
> > SIZE 12
> > END
> > END
> > Now in my data I have these values (below), although every symbol was
> > displayed in the map
> > NOTE THIS IS A TEXT FIELD
> > 081204, 081225,090118
> > These values (above) for the Year, Month, Day format specified in the
> > map source are clearly less than the “last two weeks”, Where as they are
> > older than the last 14 days….so none of them should show up, but they do
> > Any thoughts
> > [mailto:mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Bob
> Basques
> > *Sent:* Friday, September 17, 2010 9:25 PM
> > *To:* mapserver-users at lists.osgeo.org
> > *Subject:* Re: [mapserver-users] Expressions
> > A first stab at seeing more than one class, might be to try and switch
> > them around order wise, one filter may be overwriting the other for
> example.
> > bobb
> > On 9/17/2010 8:20 AM, Jay Kapalczynski wrote:
> > I am using GeoMoose but feel this is more a question for Map Server.
> > I am trying to sort my points by dates using the code below….I think
> > that I can do this but not sure
> > Is this a viable format “2Y%2M%2D” ?
> > As for the field in the shapefile…If I use an integer it removes the 0
> > from the 092110, (sept 21^st 2010)
> > If I use a date then there are “/” … 9/21/10
> > The only way I can see this happening is using a text field with retains
> > the 0 in 092110
> > When I use the textfield “dateValues” as seen below I can get the stars
> > to draw but only the LASTWEEK…for some reason the LASTTWOWEEKS does not
> > show and I know that I have a few records with dates in the last 14 days…
> > Thoughts?
> > THANKS….all your help is very appreciated….
> > Main .xml file
> > </map-source>
> > .map file
> > CLASS
> > NAME 'Last Weeks'
> > EXPRESSION ('[dateValues]' > '%LASTWEEK%')
> > STYLE
> > COLOR 0 0 0
> > SYMBOL "star"
> > SIZE 12
> > END
> > END
> > CLASS
> > NAME 'Last Two Weeks'
> > STYLE
> > COLOR 0 100 50
> > SYMBOL "star"
> > SIZE 12
> > END
> > END
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
