[mapserver-users] Internal Server Error / proxy.cgi Fixed
Simone Lella
lella.s at irea.cnr.it
Thu Sep 30 03:18:19 EDT 2010
I've installed Python 2.7 and I've changed the first row of
"Proxy.cgi" file with "#! C:/Python27/python.exe -u"
Simone
Simone Lella
Istituto per il Rilevamento Elettromagnetico dell'Ambiente
IREA - CNR (http://www.irea.cnr.it)
Via Bassini, 15
Tel. +39 02-23699299
Milano
Il 23/09/2010 11:13, Simone Lella ha scritto:
> Hi,
> I'm using MS4W with Windows 7.
> When I call "http://localhost:8081/cgi-bin/proxy.cgi", the response is:
> /Internal Server Error
> /The server encountered an internal error or misconfiguration and was
> unable to complete your request./
> /Please contact the server administrator, admin at local.domain and
> inform them of the time the error occurred, and anything you might
> have done that may have caused the error./
> /More information about this error may be available in the server
> error log.
> The "error.log" file contains:
> /[Thu Sep 23 09:49:43 2010] [warn] PassEnv variable PYTHONPATH was
> undefined
> [Thu Sep 23 09:49:43 2010] [notice] Apache/2.2.10 (Win32) configured
> -- resuming normal operations
> [Thu Sep 23 09:49:43 2010] [notice] Server built: Oct 10 2008 12:39:04
> [Thu Sep 23 09:49:43 2010] [notice] Parent: Created child process 2932
> undefined
> [Thu Sep 23 09:49:44 2010] [warn] PassEnv variable PYTHONPATH was
> undefined
> [Thu Sep 23 09:49:44 2010] [notice] Child 2932: Child process is running
> [Thu Sep 23 09:49:44 2010] [notice] Child 2932: Acquired the start mutex.
> [Thu Sep 23 09:49:44 2010] [notice] Child 2932: Starting 64 worker
> threads.
> [Thu Sep 23 09:49:44 2010] [notice] Child 2932: Starting thread to
> listen on port 8081.
> [Thu Sep 23 09:50:13 2010] [error] [client 127.0.0.1] (OS
> 2)Impossibile trovare il file specificato. : couldn't create child
> process: 720002: proxy.cgi
> 2)Impossibile trovare il file specificato. : couldn't spawn child
> process: C:/ms4w/Apache/cgi-bin/proxy.cgi/
> The "proxy.cgi" file was created in "C:/ms4w/Apache/cgi-bin/proxy.cgi"
> and I've copied into the following text:
> /#!/usr/bin/env python
> """This is a blind proxy that we use to get around browser
> restrictions that prevent the Javascript from loading pages not on the
> same server as the Javascript. This has several problems: it's less
> efficient, it might break some sites, and it's a security risk because
> people can use this proxy to browse the web and possibly do bad stuff
> with it. It only loads pages via http and https, but it can load any
> content type. It supports GET and POST requests."""
> import urllib2
> import cgi
> import sys, os
> # Designed to prevent Open Proxy type stuff.
> allowedHosts = ['www.openlayers.org', 'openlayers.org',
> 'labs.metacarta.com', 'world.freemap.in',
> 'prototype.openmnnd.org', 'geo.openplans.org',
> 'sigma.openplans.org', 'demo.opengeo.org',
> 'www.openstreetmap.org', 'sample.azavea.com',
> 'v-swe.uni-muenster.de:8080',
> 'vmap0.tiles.osgeo.org','localhost:8081']
> method = os.environ["REQUEST_METHOD"]
> if method == "POST":
> qs = os.environ["QUERY_STRING"]
> d = cgi.parse_qs(qs)
> if d.has_key("url"):
> url = d["url"][0]
> else:
> url = "http://www.openlayers.org"
> else:
> fs = cgi.FieldStorage()
> url = fs.getvalue('url', "http://www.openlayers.org")
> try:
> host = url.split("/")[2]
> if allowedHosts and not host in allowedHosts:
> print "Status: 502 Bad Gateway"
> print "Content-Type: text/plain"
> print
> print "This proxy does not allow you to access that location
> (%s)." % (host,)
> print
> print os.environ
> elif url.startswith("http://") or url.startswith("https://"):
> length = int(os.environ["CONTENT_LENGTH"])
> headers = {"Content-Type": os.environ["CONTENT_TYPE"]}
> body = sys.stdin.read(length)
> r = urllib2.Request(url, body, headers)
> y = urllib2.urlopen(r)
> else:
> y = urllib2.urlopen(url)
> # print content type header
> i = y.info()
> if i.has_key("Content-Type"):
> print "Content-Type: %s" % (i["Content-Type"])
> else:
> print
> print y.read()
> y.close()
> else:
> print
> print "Illegal request."
> except Exception, E:
> print "Status: 500 Unexpected Error"
> print
> print "Some unexpected error occurred. Error text was:", E/
> I've modified "proxy.cgi" file at "allowedHosts" by adding
> "localhost:8081".
> I must modify the first row of "proxy.cgi" file?
> Can this issue related to the Windows 7 OS?
> Thanks
> Simone
> *_
> _*
> Simone Lella
> Via Bassini, 15
> Milano
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100930/b335e29a/attachment.html
