[mapserver-users] lighttpd, TNS:could not resolve...
Sebastian E. Ovide
sebastian.ovide at gmail.com
Thu Sep 30 05:47:30 EDT 2010
the message says:
ORA-12154: TNS:could not resolve the connect identifier specified in
<unnamed>
so... does <unnamed> mean that gdal didn't get any name for the connection ?
On Thu, Sep 30, 2010 at 9:54 AM, Sebastian E. Ovide <
sebastian.ovide at gmail.com> wrote:
> no luck...
> renamed servicename to capital.. so now connection name==service name...
> same problem... ogrinfo works, mapserver doesn't....
> On Thu, Sep 30, 2010 at 9:37 AM, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi
> > wrote:
>> Hi,
>> For me, sometimes with some Oracle user name from some computers SQL*Plus
>> does not understand if I am using the SERVICE_NAME. It you happen to have
>> the same situation you should be able to connect with the connection name,
>> which seems to be MFUATDB for you.
>> Actually, the error message "TNS:could not resolve the connect identifier
>> specified" may mean that you should not use service name but the connect
>> identifier. Have a try and tell how it went.
>> -Jukka Rahkonen-
>> *Lähettäjä:* mapserver-users-bounces at lists.osgeo.org [mailto:
>> mapserver-users-bounces at lists.osgeo.org] *Puolesta *Sebastian E. Ovide
>> *Lähetetty:* 30. syyskuuta 2010 11:15
>> *Vastaanottaja:* Dan Little
>> *Kopio:* mapserver-users at lists.osgeo.org
>> *Aihe:* Re: [mapserver-users] lighttpd, TNS:could not resolve...
>> yes.
>> gis at mapserver:~$ ls -la /home/gis/conf/tnsnames.ora
>> -rw-r--r-- 1 gis gis 184 2010-09-29 16:19 /home/gis/conf/tnsnames.ora
>> gis at mapserver:~$ sudo su www-data -c 'cat /home/gis/conf/tnsnames.ora'
>> MFUATDB =
>> (DESCRIPTION =
>> (ADDRESS = (PROTOCOL = TCP)(HOST = 192.168.60.70)(PORT = 1521))
>> (CONNECT_DATA =
>> (SERVER = DEDICATED)
>> (SERVICE_NAME = mfuatdb)
>> On Wed, Sep 29, 2010 at 7:58 PM, Dan Little <danlittle at yahoo.com> wrote:
>>> Is tnsnames.ora accessible by the web-server user? (Check the
>>> permissions.)
>>> Is t
>>> *From:* Sebastian E. Ovide <sebastian.ovide at gmail.com>
>>> *To:* mapserver-users at lists.osgeo.org
>>> *Sent:* Wed, September 29, 2010 11:10:09 AM
>>> *Subject:* [mapserver-users] lighttpd, TNS:could not resolve...
>>> Hi All,
>>> I have installed MapServer on lighttpd + fastcgi.
>>> fastcgi.server = (
>>> "/mapserver" =>
>>> ( "localhost" =>
>>> "socket" => "/tmp/mapserver-fastcgi.socket",
>>> "bin-path" => "/home/gis/bin/mapserv",
>>> "bin-environment" =>
>>> "TNS_ADMIN" => "/home/gis/conf/"
>>> "max-procs" => 2,
>>> "check-local" => "disable"
>>> gis at mapserver:~$ cat /home/gis/conf/tnsnames.ora
>>> MFUATDB =
>>> (DESCRIPTION =
>>> (CONNECT_DATA =
>>> and I'm getting:
>>> msDrawMap(): Image handling error. Failed to draw layer named 'TESTII'.
>>> msOGRFileOpen(): OGR error. Open failed for OGR connection in layer
>>> `TESTII'. ORA-12154: TNS:could not resolve the connect identifier specified
>>> in <unnamed>
>>> from the logs:
>>> [Wed Sep 29 17:00:13 2010].649965 CGI Request 1 on process 1513
>>> [Wed Sep 29 17:00:13 2010].717290 msOGRFileOpen(): OGR error. Open failed
>>> for OGR connection in layer `TESTII'.
>>> in <unnamed>
>>> [Wed Sep 29 17:00:13 2010].717319 msDrawMap(): Image handling error.
>>> [Wed Sep 29 17:00:13 2010].717454 msFreeMap(): freeing map at 0xa00f298.
>>> [Wed Sep 29 17:00:13 2010].717579 freeLayer(): freeing layer at
>>> 0xa0237a0.
>>> [Wed Sep 29 17:00:13 2010].717591 freeLayer(): freeing layer at
>>> 0xa024718.
>>> in mapserver:
>>> LAYER
>>> NAME TESTII
>>> TYPE POLYGON
>>> STATUS ON
>>> CONNECTION "OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb"
>>> CONNECTIONTYPE OGR
>>> DATA "CA_WILDFIRE"
>>> PROJECTION
>>> "init=epsg:3857"
>>> END
>>> CLASS
>>> # NAME "local_shape"
>>> COLOR 0 0 255
>>> OUTLINECOLOR 0 0 255
>>> END
>>> END
>>> The connection string is right as I'm using it from gdal:
>>> gis at mapserver:~$ ogrinfo OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb
>>> :CA_WILDFIRE
>>> INFO: Open of `OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb:CA_WILDFIRE'
>>> using driver `OCI' successful.
>>> 1: CA_WILDFIRE
>>> any ideas ?
>>> Sebastian E. Ovide
>> Sebastian E. Ovide
> Sebastian E. Ovide
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100930/d9424de0/attachment.html
