[mapserver-users] Re: WFS Client through Proxy and HTTP
Authentication
bteluk at gmail.com
bteluk at gmail.com
Tue Aug 9 22:29:13 EDT 2011
Thanks Daniel,
I can't get the actual IP because I'm behind a proxy, on an intranet. But I
know the proxy can correctly resolve the URL, because it works fine when I
send a WMS request into my server (which then successfully sends a WMS
request back out to the external source.) Likewise if I manually generate
the WFS requests on the server using curl, it works fine (noting that I have
to specify the proxy name and credentials.)
It seems as if something is preventing the WFS request from using the same
"proxy handling" metadata as per the WMS request. I've checked the curl
installation and it certainly works using manual parameters for the proxy to
the same external WFS URL.
I've tried a packet trace whilst sending the request to my map server - for
WMS, I can that it performs look-ups to the local DNS for the proxy and then
communicates with the proxy from then on for the rest of the transaction
(expected behaviour.) But for WFS, it doesn't attempt a DNS lookup for the
proxy or even connect to it - it just tries to get the WFS request out using
the local DNS - which fails of course because I'm in an intranet environment
where the DNS can't see the Internet.
I've attached my full map file - the WMS is a separate layer and works fine.
The "localhost:20080" references are to overcome the server being behind a
private network within the Intranet - localhost:20080 is a PuTTY tunnel to
access the server - the server itself can get out to the Internet fine when
using proxy & credentials.
Regards, Bill Teluk
http://osgeo-org.1803224.n2.nabble.com/file/n6670606/bom.map bom.map
Regards, Bill Teluk
View this message in context: http://osgeo-org.1803224.n2.nabble.com/WFS-Client-through-Proxy-and-HTTP-Authentication-tp6670451p6670606.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
