[mapserver-users] Re: WFS Client through Proxy and
HTTP Authentication
bteluk at gmail.com
bteluk at gmail.com
Wed Aug 10 01:50:03 EDT 2011
Hi Daniel,
Thanks for confirming the problem - now I know it's not a fault with my
config. Much appreciated!
Thanks very much for writing a patch so quickly - I'm not able to take
advantage of it immediately but I may be able to, further down the track.
Regards, Bill Teluk.
Daniel Morissette wrote:
> Hi Bill,
> It turns out that proxy and auth support is not implemented in the WFS
> client layer code. It is only present in the WMS layer code.
> I have created a ticket for this and attached an untested patch to it:
> http://trac.osgeo.org/mapserver/ticket/3982
> The final fix will require a cleaner job, but this quick patch should
> work if you are able to build from source.
> Daniel
> On 11-08-09 10:29 PM, bteluk at gmail.com wrote:
>> Thanks Daniel,
>> I can't get the actual IP because I'm behind a proxy, on an intranet.
>> But I
>> know the proxy can correctly resolve the URL, because it works fine when
>> I
>> send a WMS request into my server (which then successfully sends a WMS
>> request back out to the external source.) Likewise if I manually
>> generate
>> the WFS requests on the server using curl, it works fine (noting that I
>> have
>> to specify the proxy name and credentials.)
>> It seems as if something is preventing the WFS request from using the
>> same
>> "proxy handling" metadata as per the WMS request. I've checked the curl
>> installation and it certainly works using manual parameters for the proxy
>> to
>> the same external WFS URL.
>> I've tried a packet trace whilst sending the request to my map server -
>> for
>> WMS, I can that it performs look-ups to the local DNS for the proxy and
>> then
>> communicates with the proxy from then on for the rest of the transaction
>> (expected behaviour.) But for WFS, it doesn't attempt a DNS lookup for
>> the
>> proxy or even connect to it - it just tries to get the WFS request out
>> using
>> the local DNS - which fails of course because I'm in an intranet
>> environment
>> where the DNS can't see the Internet.
>> I've attached my full map file - the WMS is a separate layer and works
>> fine.
>> The "localhost:20080" references are to overcome the server being behind
>> a
>> private network within the Intranet - localhost:20080 is a PuTTY tunnel
>> to
>> access the server - the server itself can get out to the Internet fine
>> when
>> using proxy& credentials.
>> Regards, Bill Teluk
>> http://osgeo-org.1803224.n2.nabble.com/file/n6670606/bom.map bom.map
>> Regards, Bill Teluk
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/WFS-Client-through-Proxy-and-HTTP-Authentication-tp6670451p6670606.html
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Daniel Morissette
> http://www.mapgears.com/
> Provider of Professional MapServer Support since 2000
Regards, Bill Teluk
View this message in context: http://osgeo-org.1803224.n2.nabble.com/WFS-Client-through-Proxy-and-HTTP-Authentication-tp6670451p6671111.html
