[mapserver-users] WFS Spatial Filter Problem
Bryan Hempen
bhempen at sciops.esa.int
Wed Aug 10 08:35:06 EDT 2011
Hi David,
I enabled debugging using the following settings:
CONFIG "MS_ERRORFILE" "/home/bhempen/ms_error.txt"
DEBUG 5
CONFIG "CPL_DEBUG" "ON"
CONFIG "PROJ_DEBUG" "ON"
The only line that shows up after I got an error 500 using the spatial
filter is:
[Wed Aug 10 14:30:46 2011].451858 CGI Request 1 on process 21100
Not really helpful, right?
Regards,
Bryan
On 09/08/2011 15:38, Fawcett, David (MPCA) wrote:
> Bryan,
> For testing, I would enable debugging at the MAP or LAYER level. If
> you set DEBUG 5, I think that you should be able to see the query that
> MapServer is crafting.
> More on debugging here:
> http://mapserver.org/optimization/debugging.html#debugging
> David.
> *From:*mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Bryan
> Hempen
> *Sent:* Tuesday, August 09, 2011 4:15 AM
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] WFS Spatial Filter Problem
> Dear Kai and Assefa,
> After you two guys requested me to send you my setup, I exported the
> content in the databasetable to a shapefile so you can test it. When I
> tested the spatial filter right after that, it suddenly worked ! This
> narrows down the possibilities:
> - The request I send is definitely not the problem anymore. It works
> with MapServer + shapefile and with GeoServer.
> - I exported only the geometries to the shapefile in the table with
> geometrytype = POLYGON because from ~8000 geometries ~10 are
> linestrings. So I investigated possible problems with the linestring
> geometries by telling the MapServer not to serve them using a subquery
> in the mapfile:
> DATA "the_geom from (select * from alldata where
> geometrytype(the_geom) = 'POLYGON') as subquery using unique
> product_id using SRID=4326"
> Error 500 still occured. Therefore, the data can't be the problem
> neither, right?
> - Since I didn't change anything else MapServer must have problems
> communicating with the PostGIS database, but why Error 500 then?
> Here is my mapfile:
> MAP
> NAME "WFS Server"
> STATUS ON
> SIZE 600 400
> SYMBOLSET
> "/var/www/html/psa/bhempen/mapservertest/symbols/symbols.sym"
> EXTENT -180 -90 180 90
> UNITS DD
> SHAPEPATH "/var/www/html/psa/bhempen/mapservertest/data/"
> IMAGECOLOR 255 255 255
> FONTSET "/var/www/html/psa/bhempen/mapservertest/fonts/fonts.list"
> MAXSIZE 4096 # needs to be set because otherwise an error will
> appear when rendering images on large screens
> #IMAGECOLOR 200 200 200 #commented out for WFS
> PROJECTION
> 'init=epsg:4326'
> END
> WEB
> TEMPLATE '/var/www/html/psa/bhempen/mapservertest/template.html'
> IMAGEPATH '/var/www/html/psa/bhempen/tmp/'
> IMAGEURL '/psa/bhempen/tmp/'
> METADATA
> "wfs_title" "WFS Demo Server for
> MapServer" ## REQUIRED
> "wfs_onlineresource"
> "http://localhost/cgi-bin/psa/mapserv?map=/home/bhempen/wfs.map&"
> <http://localhost/cgi-bin/psa/mapserv?map=/home/bhempen/wfs.map&> ##
> Recommended
> "wfs_srs" "EPSG:4326" ## Recommended
> "wfs_abstract" "This text describes my WFS
> service." ## Recommended
> END
> END
> LAYER
> NAME "omega"
> STATUS DEFAULT
> TYPE POLYGON
> METADATA
> "wfs_title" "omega footprints" ##REQUIRED
> "wfs_srs" "EPSG:4326" ## REQUIRED
> "gml_include_items" "all" ## Optional (serves all
> attributes for layer)
> "gml_featureid" "product_id" ## REQUIRED
> END
> PROJECTION
> "init=epsg:4326"
> END
> CONNECTIONTYPE POSTGIS
> CONNECTION "host=localhost port=xxx dbname=xxx user=xxx password=xxx"
> DATA "the_geom from alldata using unique product_id using SRID=4326"
> CLASS
> STYLE
> OUTLINECOLOR 125 0 0
> END
> END
> DUMP TRUE ## REQUIRED
> END # layer
> END
> Does anyone see a problem with the setup?
> Many thanks to Kai and Assefa for the help so far! I am going to send
> you the shapefile (which you could import into the database with
> pgsql2shp), the mapfile, and my client.
> Kind regards,
> Bryan
> This message and any attachments are intended for the use of the addressee or addressees only. The unauthorised disclosure,
> use, dissemination or copying (either in whole or in part) of its content is not permitted. If you received this message in
> error, please notify the sender and delete it from your system. Emails can be altered and their integrity cannot be guaranteed by
> the sender.
> Please consider the environment before printing this email.
the sender.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110810/4833fda1/attachment-0001.html
