[mapserver-users] Invalid pdf file from WMS
thomas bonfort
thomas.bonfort at gmail.com
Wed Aug 17 15:56:45 EDT 2011
if gdb is installed on the system, you do:
gdb /path/to/mapserv
$ run QUERY_STRING='map=...&....'
(...program runs and spits out the beginning of the pdf..., then segfaults)
$ bt
thomas
On Wed, Aug 17, 2011 at 21:36, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
> Command with big BBOX does lead into segmantation fault. Unfortunately I am just an amateur and I have no idea about what is a backtrace and how I could provide it to you. The server is a virtual Linux box (Ubuntu).
> -Jukka Rahkonen-
> thomas bonfort wrote:
>> the second one is incomplete, the request seems to be failing.
>> can you run the request locally to see if it segfaults, and if so
> provide a backtrace:
>> /path/to/mapserver-cgi
> QUERY_STRING='map=/path/to/map&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDTH=864&HEIGHT=662&LAYERS=default&TRANSPARENT=TRUE&FORMAT=application/x-pdf&BBOX=3409763.750050978,6956187.032331026,3411904.266676571,6957827.104097395&SRS=EPSG:2393&STYLES='
> thomas
> On Wed, Aug 17, 2011 at 15:40, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
>> Hi,
>>> This request from Mapserver 6.0 gives me a nice pdf file:
>>> http://188.64.1.61/cgi-bin/osm-mapserver_i?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDTH=864&HEIGHT=662&LAYERS=default&TRANSPARENT=TRUE&FORMAT=application/x-pdf&BBOX=3409763.750050978,6956187.032331026,3411904.266676571,6957827.104097395&SRS=EPSG:2393&STYLES=
>> However, if I double the bounding box the resulting pdf cannot be opened by Acrobat reader.
>> http://188.64.1.61/cgi-bin/osm-mapserver_i?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDTH=1728&HEIGHT=1324&LAYERS=default&TRANSPARENT=TRUE&FORMAT=application/x-pdf&BBOX=3409763.750050978,6956187.032331026,3411904.266676571,6957827.104097395&SRS=EPSG:2393&STYLES=
>> The latter gives fine image with format=image/png. Any idea about what is going wrong?
>> -Jukka Rahkonen-_______________________________________________
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
