[mapserver-users] Map size question?
Fawcett, David (MPCA)
david.fawcett at state.mn.us
Thu Aug 18 13:38:08 EDT 2011
Chris,
If you are in tile mode, I assume that you probably don't want an embedded legend on each tile.
Have you thought about doing a separate call/request/object for the legend?
If you were doing this via CGI, I would recommend doing a separate mode=legend request.
David.
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Chris Green
Sent: Thursday, August 18, 2011 12:04 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Map size question?
After quite a while thinking I could not produce a legend I have realised that the legend is actually there, just off the edge of my map.
Now I see that although my map file specifies a map size of 640 x 480 pixels, if in single tile mode the map image being produced is actually 1110 x 660 pixels. Alternatively with multiple tiles I get 12 tiles of 250 x 250 pixels which is 1024 x 768 pixels.
It seems that the size parameter in the map file is being ignored (even setting the values to 0 0 or omitting the SIZE parameter altogether makes no difference). MAXSIZE doesn't seem to help either.
I can't find a way to get the image size that I want, can anyone help?
Chris
Sent: 18 August 2011 08:02
Subject: [mapserver-users] mapsript legend
Hi all
I have a map created via Mapscript under Mapserver 6.0 but I can't find a way to add a legend. Recent examples are hard to find but I found the following dating from 2002 which seemed simple enough:
$legend = $map->legend;
$legend->set(width,40);
$legend->set(height,100);
$legend->imagecolor->setRGB(240,220,200); # tan
$legend->outlinecolor->setRGB(1,1,1); # black
$legend->set(status, MS_EMBED);
$legend->set(position, MS_UL);
// SET LEGEND LABEL PROPERTIES
$lg_label = $legend->label;
$lg_label->set(font, "arial");
$lg_label->set(type, MS_TRUETYPE);
$lg_label->set(size, 10);
$lg_label->set(minsize, 6);
$lg_label->set(maxsize, 12);
$lg_label->color->setRGB(100,100,100);
$legend->set(postlabelcache, MS_TRUE);
// DRAW LEGEND
$legendImage=$map->drawLegend();
Unfortunately this produces no output. Can anyone give me any clues why?
Chris
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110818/b4be864f/attachment.html
