[mapserver-users] Problem displaying a NAD83 tile in WGS84 (or
via WMS)
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Aug 19 00:51:00 EDT 2011
Could you give a bit more information? Your use case is the most common that exists and all instructions should be at http://mapserver.org/ogc/wms_server.html
It would be good to see the gdalinfo report of your image and your mapfile and the exact WMS request you were using including the WMS version. At least these parts of mapfile are important
MAP level: extent, projection and metadata (wms_srs and wms_inable_request at least)
LAYER level projection.
I can see some really odd LatLonBoundingBoxes in my own MS 6.0 WMS service too. I will investigate them a bit further. If it is just that the Mapserver is creating the GetCapabilities document wrong then the WMS service should still be usable.
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Ed Resnick
> Lähetetty: 19. elokuuta 2011 2:47
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] Problem displaying a NAD83 tile in
> WGS84 (or via WMS)
> I have a MrSID file in NAD83 projection (EPGS 4269) which I
> want to display via WMS in WGS84 projection (EPGS 4326). I
> cannot get this to work.
> I have tried setting the entire map-file's projection to
> 4269, with the extent specified in that projection (in
> meters), and shp2img shows the image, but attempting to view
> it via WMS (requesting the 4326 projection) does not work,
> and the GetCapabilities response file is completely wrong -
> the LatLonBoundingBox tags actually list the 4269 bounding
> box in meters. Excerpt:
> <LatLonBoundingBox minx="555230" miny="5.04658e+006"
> maxx="556972" maxy="5.04804e+006" />
> <BoundingBox SRS="EPSG:4269"
> The BoundingBox is correct; the LatLonBoundingBox obviously is not.
> I have also tried specifying 4326 as the map projection and
> 4269 as the layer projection, with the map's extent in
> lat/lon and the layer's extent as the above value (meters).
> Not only did this not work, but even shp2img just shows a
> blank image. If I change the map's extent to the value in
> meters (even though its projection is specified as 4326),
> then shp2img works, but the WMS feed still does not; the
> GetCapabilities still is wrong.
> Is MapServer simply buggy or is there a
> solution?_______________________________________________
