[mapserver-users] How to define this projection?
jjwang
jaja0506 at gmail.com
Wed Aug 24 21:48:21 EDT 2011
This the summary of my shapefile.
Layer name: tas101sb
Geometry: Polygon
Feature Count: 971
Extent: (143.833316, -43.742980) - (148.498760, -39.437430)
Layer SRS WKT:
GEOGCS["GCS_WGS_1984",
DATUM["WGS_1984",
SPHEROID["WGS_1984",6378137.0,298.257223563]],
PRIMEM["Greenwich",0.0],
*UNIT["Degree",0.0174532925199433]]*
AREA: Real (20.5)
PERIMETER: Real (20.5)
TAS101SB_: Real (11.0)
TAS101SB_I: Real (11.0)
SUBURB: String (46.0)
SOURCE: String (16.0)
UFI: Integer (10.0)
I'm assuming that 'Layers SRS WKT' defines the projection of the layer.
Is this projection same as EPSG:4326?
If not, can some one give me the Proj4 statement that defines this
projection.
JJ
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-define-this-projection-tp6722964p6722964.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
