[mapserver-users] msQueryByFilter(): Search returned no results.
Michal Šrédl
michal.sredl at gmail.com
Thu Aug 25 11:24:27 EDT 2011
Hi all,
problem solved. I needed to set:
EXTENT -905000 -1230000 -400000 -900000
and
PROJECTION
## "init=epsg:4326"
"init=epsg:102067"
END
(Epsg 102067 is the projection of the layer being filtered.)
Thank you very much again,
Michal
2011/8/25 Michal Šrédl <michal.sredl at gmail.com>:
> Hi Steve,
> Thanks a lot. The extent should be large enough to encompass all the
> features. Here comes the whole mapfile:
> MAP
> NAME "MIS WFS Server"
> STATUS ON
> SIZE 500 500
> EXTENT -180 -90 180 90
> SHAPEPATH "data/"
> IMAGECOLOR 255 255 255
> CONFIG MS_ERRORFILE "log/mapserv.log"
> DEBUG 5
> WEB
> IMAGEPATH "/var/www/tmp/"
> IMAGEURL "/tmp/"
> METADATA
> "wfs_title" "MIS WFS Server" ## REQUIRED
> "wfs_onlineresource" "http://127.0.0.1/cgi-bin/ows?"
> "wfs_srs" "EPSG:4326 EPSG:102067"
> "wms_srs" "EPSG:4326 EPSG:102067" ## Recommended
> "wcs_srs" "EPSG:4326 EPSG:102067" ## Recommended
> "ows_enable_request" "*"
> "ows_updatesequence" "2011-29-05T00:24:00"
> END
> END
> PROJECTION
> "init=epsg:4326"
> END
> LAYER
> NAME "typ"
> METADATA
> "wfs_title" "Typologie" ## REQUIRED
> "wfs_include_items" "all"
> "gml_featureid" "CISLO" ## REQUIRED
> "gml_include_items" "all" ## Optional (serves all attributes for layer)
> "gml_types" "auto"
> "gml_geometries" "msGeometry"
> "gml_msGeometry_type" "polygon"
> END
> DATA typ.shp
> TYPE POLYGON
> STATUS ON
> PROJECTION
> "init=epsg:102067"
> END
> DUMP TRUE ## REQUIRED
> CLASS
> NAME "Typ"
> STYLE
> COLOR 0 0 155
> OUTLINECOLOR 120 120 120
> END
> TEMPLATE "templates/typ_zver.html"
> END
> DEBUG 5
> END # Layer
> LAYER
> NAME "hsrs"
> TYPE RASTER
> STATUS ON
> CONNECTION "http://www.bnhelp.cz/cgi-bin/crtopo?"
> DEBUG ON
> CONNECTIONTYPE WMS
> METADATA
> "wms_srs" "EPSG:4326"
> "wms_name" "obce,kraje,hr_cr,sidla,doprava"
> "wms_title" "CR Topo"
> "wms_server_version" "1.1.1"
> "wms_format" "image/png"
> "wms_latlonboundingbox" "11.9384 48.2337 18.957 51.3549"
> END
> END
> END # Map File
> Cheers,
> Michal
> 2011/8/25 Steve Lime <sdlime at gmail.com>:
>> What is your default EXTENT set to in your mapfile? It should be large enough to encompass all features. - Steve
>> Sent from my iPad
>> On Aug 24, 2011, at 7:58 AM, Michal Šrédl <michal.sredl at gmail.com> wrote:
>>> Hi all,
>>> I am trying to use FES filter for WFS layer and get no result, even
>>> thought I should get one.
>>> In my browser, I request
>>> http://localhost//cgi-bin/ows?&REQUEST=GetFeature&VERSION=1.1.0&SERVICE=WFS&TYPENAME=typ&FILTER=<ogc:Filter
>>> xmlns:ogc="http://www.opengis.net/ogc"><ogc:PropertyIsEqualTo><ogc:PropertyName>ZVER</ogc:PropertyName><ogc:Literal>2</ogc:Literal></ogc:PropertyIsEqualTo></ogc:Filter>
>>> and get
>>> <wfs:FeatureCollection
>>> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>>> xmlns:gml="http://www.opengis.net/gml"
>>> xmlns:wfs="http://www.opengis.net/wfs"
>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>> xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver
>>> http://127.0.0.1/cgi-bin/ows?SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=typ&OUTPUTFORMAT=text/xml;%20subtype=gml/3.1.1
>>> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
>>> <gml:boundedBy>
>>> <gml:Null>missing</gml:Null>
>>> </gml:boundedBy>
>>> </wfs:FeatureCollection>
>>> even though I do know, that features with ZVER=2 do exist.
>>> In the mapserver log file, I get
>>> [Wed Aug 24 14:48:52 2011].296607 msQueryByFilter(): Search returned
>>> no results. No matching record(s) found.
>>> [Wed Aug 24 14:48:52 2011].296747 mapserv request processing time
>>> (msLoadMap not incl.): 0.002s
>>> [Wed Aug 24 14:48:52 2011].296764 msFreeMap(): freeing map at 0x2783120.
>>> [Wed Aug 24 14:48:52 2011].296773 freeLayer(): freeing layer at 0x278b570.
>>> I have checked http://mapserver.org/errors.html#id2 with similar error
>>> "msQueryByPoint: search returned no results" and tried to create a
>>> simple template:
>>> <!-- MapServer Template -->
>>> <tr>
>>> <td>[lrn]</td>
>>> <td>[ZVER]</td>
>>> </tr>
>>> but with no effect.
>>> In the mapfile, there is
>>> LAYER
>>> NAME "typ"
>>> METADATA
>>> "gml_types" "auto"
>>> END
>>> DATA typ.shp
>>> TYPE POLYGON
>>> STATUS ON
>>> PROJECTION
>>> "init=epsg:102067"
>>> END
>>> CLASS
>>> NAME "Typ"
>>> STYLE
>>> COLOR 0 0 155
>>> END
>>> END
>>> DEBUG 5
>>> END # Layer
>>> What is wrong with my FES filter? How can I make it to run?
>>> Thanks a lot,
>>> Michal
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
