[mapserver-users] msQueryByFilter(): Search returned no results.
Michal Šrédl
michal.sredl at gmail.com
Fri Aug 26 11:50:37 EDT 2011
Hi Steve,
regardless of the projection settings, I get the following result:
For
http://localhost//cgi-bin/ows?map=mapfile&mode=itemnquery&qlayer=typ&qitem=zver&qstring=2
I see
msLoadMap(): Regular expression error. MS_DEFAULT_MAPFILE_PATTERN
validation failed. msEvalRegex(): Regular expression error. String
failed expression test.
And for
http://localhost//cgi-bin/ows?mode=itemnquery&qlayer=typ&qitem=zver&qstring=2
I see
mapserv(): Web application error. Parameter 'qstring' value fails to
validate. msValidateParameter(): Regular expression error. Parameter
pattern validation failed.
Cheers,
Michal
2011/8/26 Steve Lime <sdlime at gmail.com>:
> I would agree this sounds like a bug. The map extent *should* be
> projected to the layer extent and that's what's used to identify
> candidate features. Can you check what happens with a native mapserver
> attribute query in this case? If possible try this:
> 1) set your MAP projection back to geographic, and restore your
> geographic map extent.
> 2) add this line to the layer metadata 'qstring_validation' '^[0-9]$'
> 3) go to the following URL:
> http://localhost//cgi-bin/ows?map=[yourmapfile]&mode=itemnquery&qlayer=typ&qitem=zver&qstring=2
> and see what happens.
> This will run a different query function msQueryByAttributes() that's
> not new to 6.0.x.
> Steve
> 2011/8/26 Michal Šrédl <michal.sredl at gmail.com>:
>> Hi Jukka,
>> the current settings returns expected result with &srsName=EPSG:4326
>> as well. The original settings doesn't work neither with
>> &srsName=EPSG:4326 nor &srsName=EPSG::102067.
>> Yes, it looks like there would be a problem in case of several WFS
>> layers with different projections of the source data.
>> Cheers,
>> Mike
>> 2011/8/26 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>:
>>> Hi,
>>> Good that you could make it to work. However, this feels maybe like a bug if it means that using ogc:PropertyIsEqualTo filter without any other filter works only if projection of the source data is the same than the default output projection from WFS.
>>> Could you have one more trial with the original settings and see if adding &srsName=EPSG:4326 or &srsName=EPSG::102067 is changing anything? And also if your current setting gives correct result with &srsName=EPSG:4326.
>>> -Jukka Rahkonen.
>>> Michal Šrédl wrote:
>>>> Hi all,
>>>> problem solved. I needed to set:
>>>> EXTENT -905000 -1230000 -400000 -900000
>>> and
>>> PROJECTION
>>> ## "init=epsg:4326"
>>> "init=epsg:102067"
>>> END
>>> (Epsg 102067 is the projection of the layer being filtered.)
>>> Thank you very much again,
>>> Michal
>>> 2011/8/25 Michal Šrédl <michal.sredl at gmail.com>:
>>>> Hi Steve,
>>>> Thanks a lot. The extent should be large enough to encompass all the
>>>> features. Here comes the whole mapfile:
>>>> MAP
>>>> NAME "MIS WFS Server"
>>>> STATUS ON
>>>> SIZE 500 500
>>>> EXTENT -180 -90 180 90
>>>> SHAPEPATH "data/"
>>>> IMAGECOLOR 255 255 255
>>>> CONFIG MS_ERRORFILE "log/mapserv.log"
>>>> DEBUG 5
>>>> WEB
>>>> IMAGEPATH "/var/www/tmp/"
>>>> IMAGEURL "/tmp/"
>>>> METADATA
>>>> "wfs_title" "MIS WFS Server" ## REQUIRED
>>>> "wfs_onlineresource" "http://127.0.0.1/cgi-bin/ows?"
>>>> "wfs_srs" "EPSG:4326 EPSG:102067"
>>>> "wms_srs" "EPSG:4326 EPSG:102067" ## Recommended
>>>> "wcs_srs" "EPSG:4326 EPSG:102067" ## Recommended
>>>> "ows_enable_request" "*"
>>>> "ows_updatesequence" "2011-29-05T00:24:00"
>>>> END
>>>> END
>>>> PROJECTION
>>>> "init=epsg:4326"
>>>> END
>>>> LAYER
>>>> NAME "typ"
>>>> METADATA
>>>> "wfs_title" "Typologie" ## REQUIRED
>>>> "wfs_include_items" "all"
>>>> "gml_featureid" "CISLO" ## REQUIRED
>>>> "gml_include_items" "all" ## Optional (serves all attributes for layer)
>>>> "gml_types" "auto"
>>>> "gml_geometries" "msGeometry"
>>>> "gml_msGeometry_type" "polygon"
>>>> END
>>>> DATA typ.shp
>>>> TYPE POLYGON
>>>> STATUS ON
>>>> PROJECTION
>>>> "init=epsg:102067"
>>>> END
>>>> DUMP TRUE ## REQUIRED
>>>> CLASS
>>>> NAME "Typ"
>>>> STYLE
>>>> COLOR 0 0 155
>>>> OUTLINECOLOR 120 120 120
>>>> END
>>>> TEMPLATE "templates/typ_zver.html"
>>>> END
>>>> DEBUG 5
>>>> END # Layer
>>>> LAYER
>>>> NAME "hsrs"
>>>> TYPE RASTER
>>>> STATUS ON
>>>> CONNECTION "http://www.bnhelp.cz/cgi-bin/crtopo?"
>>>> DEBUG ON
>>>> CONNECTIONTYPE WMS
>>>> METADATA
>>>> "wms_srs" "EPSG:4326"
>>>> "wms_name" "obce,kraje,hr_cr,sidla,doprava"
>>>> "wms_title" "CR Topo"
>>>> "wms_server_version" "1.1.1"
>>>> "wms_format" "image/png"
>>>> "wms_latlonboundingbox" "11.9384 48.2337 18.957 51.3549"
>>>> END
>>>> END
>>>> END # Map File
>>>> Cheers,
>>>> Michal
>>>> 2011/8/25 Steve Lime <sdlime at gmail.com>:
>>>>> What is your default EXTENT set to in your mapfile? It should be large enough to encompass all features. - Steve
>>>>> Sent from my iPad
>>>>> On Aug 24, 2011, at 7:58 AM, Michal Šrédl <michal.sredl at gmail.com> wrote:
>>>>>> Hi all,
>>>>>> I am trying to use FES filter for WFS layer and get no result, even
>>>>>> thought I should get one.
>>>>>> In my browser, I request
>>>>>> http://localhost//cgi-bin/ows?&REQUEST=GetFeature&VERSION=1.1.0&SERVICE=WFS&TYPENAME=typ&FILTER=<ogc:Filter
>>>>>> xmlns:ogc="http://www.opengis.net/ogc"><ogc:PropertyIsEqualTo><ogc:PropertyName>ZVER</ogc:PropertyName><ogc:Literal>2</ogc:Literal></ogc:PropertyIsEqualTo></ogc:Filter>
>>>>>> and get
>>>>>> <wfs:FeatureCollection
>>>>>> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>>>>>> xmlns:gml="http://www.opengis.net/gml"
>>>>>> xmlns:wfs="http://www.opengis.net/wfs"
>>>>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>>>> xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver
>>>>>> http://127.0.0.1/cgi-bin/ows?SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=typ&OUTPUTFORMAT=text/xml;%20subtype=gml/3.1.1
>>>>>> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
>>>>>> <gml:boundedBy>
>>>>>> <gml:Null>missing</gml:Null>
>>>>>> </gml:boundedBy>
>>>>>> </wfs:FeatureCollection>
>>>>>> even though I do know, that features with ZVER=2 do exist.
>>>>>> In the mapserver log file, I get
>>>>>> [Wed Aug 24 14:48:52 2011].296607 msQueryByFilter(): Search returned
>>>>>> no results. No matching record(s) found.
>>>>>> [Wed Aug 24 14:48:52 2011].296747 mapserv request processing time
>>>>>> (msLoadMap not incl.): 0.002s
>>>>>> [Wed Aug 24 14:48:52 2011].296764 msFreeMap(): freeing map at 0x2783120.
>>>>>> [Wed Aug 24 14:48:52 2011].296773 freeLayer(): freeing layer at 0x278b570.
>>>>>> I have checked http://mapserver.org/errors.html#id2 with similar error
>>>>>> "msQueryByPoint: search returned no results" and tried to create a
>>>>>> simple template:
>>>>>> <!-- MapServer Template -->
>>>>>> <tr>
>>>>>> <td>[lrn]</td>
>>>>>> <td>[ZVER]</td>
>>>>>> </tr>
>>>>>> but with no effect.
>>>>>> In the mapfile, there is
>>>>>> LAYER
>>>>>> NAME "typ"
>>>>>> METADATA
>>>>>> "gml_types" "auto"
>>>>>> END
>>>>>> DATA typ.shp
>>>>>> TYPE POLYGON
>>>>>> STATUS ON
>>>>>> PROJECTION
>>>>>> "init=epsg:102067"
>>>>>> END
>>>>>> CLASS
>>>>>> NAME "Typ"
>>>>>> STYLE
>>>>>> COLOR 0 0 155
>>>>>> END
>>>>>> END
>>>>>> DEBUG 5
>>>>>> END # Layer
>>>>>> What is wrong with my FES filter? How can I make it to run?
>>>>>> Thanks a lot,
>>>>>> Michal
>>>>>> _______________________________________________
>>>>>> mapserver-users mailing list
>>>>>> mapserver-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
