[mapserver-users] msQueryByFilter(): Search returned no results.
Steve Lime
sdlime at gmail.com
Fri Aug 26 13:41:52 EDT 2011
You must have a default mapfile set in apache, that's cool. Use the second URL.
Change qstring_validation to qstring_validation_pattern from my first
message, my mistake.
Steve
2011/8/26 Michal Šrédl <michal.sredl at gmail.com>:
> Hi Steve,
> regardless of the projection settings, I get the following result:
> For
> http://localhost//cgi-bin/ows?map=mapfile&mode=itemnquery&qlayer=typ&qitem=zver&qstring=2
> I see
> msLoadMap(): Regular expression error. MS_DEFAULT_MAPFILE_PATTERN
> validation failed. msEvalRegex(): Regular expression error. String
> failed expression test.
> And for
> http://localhost//cgi-bin/ows?mode=itemnquery&qlayer=typ&qitem=zver&qstring=2
> I see
> mapserv(): Web application error. Parameter 'qstring' value fails to
> validate. msValidateParameter(): Regular expression error. Parameter
> pattern validation failed.
> Cheers,
> Michal
> 2011/8/26 Steve Lime <sdlime at gmail.com>:
>> I would agree this sounds like a bug. The map extent *should* be
>> projected to the layer extent and that's what's used to identify
>> candidate features. Can you check what happens with a native mapserver
>> attribute query in this case? If possible try this:
>> 1) set your MAP projection back to geographic, and restore your
>> geographic map extent.
>> 2) add this line to the layer metadata 'qstring_validation' '^[0-9]$'
>> 3) go to the following URL:
>> http://localhost//cgi-bin/ows?map=[yourmapfile]&mode=itemnquery&qlayer=typ&qitem=zver&qstring=2
>> and see what happens.
>> This will run a different query function msQueryByAttributes() that's
>> not new to 6.0.x.
>> Steve
>>> Hi Jukka,
>>> the current settings returns expected result with &srsName=EPSG:4326
>>> as well. The original settings doesn't work neither with
>>> &srsName=EPSG:4326 nor &srsName=EPSG::102067.
>>> Yes, it looks like there would be a problem in case of several WFS
>>> layers with different projections of the source data.
>>> Cheers,
>>> Mike
>>> 2011/8/26 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>:
>>>> Hi,
>>>> Good that you could make it to work. However, this feels maybe like a bug if it means that using ogc:PropertyIsEqualTo filter without any other filter works only if projection of the source data is the same than the default output projection from WFS.
>>>> Could you have one more trial with the original settings and see if adding &srsName=EPSG:4326 or &srsName=EPSG::102067 is changing anything? And also if your current setting gives correct result with &srsName=EPSG:4326.
>>>> -Jukka Rahkonen.
>>>> Michal Šrédl wrote:
>>>>> Hi all,
>>>>> problem solved. I needed to set:
>>>>> EXTENT -905000 -1230000 -400000 -900000
>>>> and
>>>> PROJECTION
>>>> ## "init=epsg:4326"
>>>> "init=epsg:102067"
>>>> END
>>>> (Epsg 102067 is the projection of the layer being filtered.)
>>>> Thank you very much again,
>>>> Michal
>>>> 2011/8/25 Michal Šrédl <michal.sredl at gmail.com>:
>>>>> Hi Steve,
>>>>> Thanks a lot. The extent should be large enough to encompass all the
>>>>> features. Here comes the whole mapfile:
>>>>> MAP
>>>>> NAME "MIS WFS Server"
>>>>> STATUS ON
>>>>> SIZE 500 500
>>>>> EXTENT -180 -90 180 90
>>>>> SHAPEPATH "data/"
>>>>> IMAGECOLOR 255 255 255
>>>>> CONFIG MS_ERRORFILE "log/mapserv.log"
>>>>> DEBUG 5
>>>>> WEB
>>>>> IMAGEPATH "/var/www/tmp/"
>>>>> IMAGEURL "/tmp/"
>>>>> METADATA
>>>>> "wfs_title" "MIS WFS Server" ## REQUIRED
>>>>> "wfs_onlineresource" "http://127.0.0.1/cgi-bin/ows?"
>>>>> "wfs_srs" "EPSG:4326 EPSG:102067"
>>>>> "wms_srs" "EPSG:4326 EPSG:102067" ## Recommended
>>>>> "wcs_srs" "EPSG:4326 EPSG:102067" ## Recommended
>>>>> "ows_enable_request" "*"
>>>>> "ows_updatesequence" "2011-29-05T00:24:00"
>>>>> END
>>>>> END
>>>>> PROJECTION
>>>>> "init=epsg:4326"
>>>>> END
>>>>> LAYER
>>>>> NAME "typ"
>>>>> METADATA
>>>>> "wfs_title" "Typologie" ## REQUIRED
>>>>> "wfs_include_items" "all"
>>>>> "gml_featureid" "CISLO" ## REQUIRED
>>>>> "gml_include_items" "all" ## Optional (serves all attributes for layer)
>>>>> "gml_types" "auto"
>>>>> "gml_geometries" "msGeometry"
>>>>> "gml_msGeometry_type" "polygon"
>>>>> END
>>>>> DATA typ.shp
>>>>> TYPE POLYGON
>>>>> STATUS ON
>>>>> PROJECTION
>>>>> "init=epsg:102067"
>>>>> END
>>>>> DUMP TRUE ## REQUIRED
>>>>> CLASS
>>>>> NAME "Typ"
>>>>> STYLE
>>>>> COLOR 0 0 155
>>>>> OUTLINECOLOR 120 120 120
>>>>> END
>>>>> TEMPLATE "templates/typ_zver.html"
>>>>> END
>>>>> DEBUG 5
>>>>> END # Layer
>>>>> LAYER
>>>>> NAME "hsrs"
>>>>> TYPE RASTER
>>>>> STATUS ON
>>>>> CONNECTION "http://www.bnhelp.cz/cgi-bin/crtopo?"
>>>>> DEBUG ON
>>>>> CONNECTIONTYPE WMS
>>>>> METADATA
>>>>> "wms_srs" "EPSG:4326"
>>>>> "wms_name" "obce,kraje,hr_cr,sidla,doprava"
>>>>> "wms_title" "CR Topo"
>>>>> "wms_server_version" "1.1.1"
>>>>> "wms_format" "image/png"
>>>>> "wms_latlonboundingbox" "11.9384 48.2337 18.957 51.3549"
>>>>> END
>>>>> END
>>>>> END # Map File
>>>>> Cheers,
>>>>> Michal
>>>>> 2011/8/25 Steve Lime <sdlime at gmail.com>:
>>>>>> What is your default EXTENT set to in your mapfile? It should be large enough to encompass all features. - Steve
>>>>>> Sent from my iPad
>>>>>> On Aug 24, 2011, at 7:58 AM, Michal Šrédl <michal.sredl at gmail.com> wrote:
>>>>>>> Hi all,
>>>>>>> I am trying to use FES filter for WFS layer and get no result, even
>>>>>>> thought I should get one.
>>>>>>> In my browser, I request
>>>>>>> http://localhost//cgi-bin/ows?&REQUEST=GetFeature&VERSION=1.1.0&SERVICE=WFS&TYPENAME=typ&FILTER=<ogc:Filter
>>>>>>> xmlns:ogc="http://www.opengis.net/ogc"><ogc:PropertyIsEqualTo><ogc:PropertyName>ZVER</ogc:PropertyName><ogc:Literal>2</ogc:Literal></ogc:PropertyIsEqualTo></ogc:Filter>
>>>>>>> and get
>>>>>>> <wfs:FeatureCollection
>>>>>>> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>>>>>>> xmlns:gml="http://www.opengis.net/gml"
>>>>>>> xmlns:wfs="http://www.opengis.net/wfs"
>>>>>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>>>>> xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver
>>>>>>> http://127.0.0.1/cgi-bin/ows?SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=typ&OUTPUTFORMAT=text/xml;%20subtype=gml/3.1.1
>>>>>>> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
>>>>>>> <gml:boundedBy>
>>>>>>> <gml:Null>missing</gml:Null>
>>>>>>> </gml:boundedBy>
>>>>>>> </wfs:FeatureCollection>
>>>>>>> even though I do know, that features with ZVER=2 do exist.
>>>>>>> In the mapserver log file, I get
>>>>>>> [Wed Aug 24 14:48:52 2011].296607 msQueryByFilter(): Search returned
>>>>>>> no results. No matching record(s) found.
>>>>>>> [Wed Aug 24 14:48:52 2011].296747 mapserv request processing time
>>>>>>> (msLoadMap not incl.): 0.002s
>>>>>>> [Wed Aug 24 14:48:52 2011].296764 msFreeMap(): freeing map at 0x2783120.
>>>>>>> [Wed Aug 24 14:48:52 2011].296773 freeLayer(): freeing layer at 0x278b570.
>>>>>>> I have checked http://mapserver.org/errors.html#id2 with similar error
>>>>>>> "msQueryByPoint: search returned no results" and tried to create a
>>>>>>> simple template:
>>>>>>> <!-- MapServer Template -->
>>>>>>> <tr>
>>>>>>> <td>[lrn]</td>
>>>>>>> <td>[ZVER]</td>
>>>>>>> </tr>
>>>>>>> but with no effect.
>>>>>>> In the mapfile, there is
>>>>>>> LAYER
>>>>>>> NAME "typ"
>>>>>>> METADATA
>>>>>>> "gml_types" "auto"
>>>>>>> END
>>>>>>> DATA typ.shp
>>>>>>> TYPE POLYGON
>>>>>>> STATUS ON
>>>>>>> PROJECTION
>>>>>>> "init=epsg:102067"
>>>>>>> END
>>>>>>> CLASS
>>>>>>> NAME "Typ"
>>>>>>> STYLE
>>>>>>> COLOR 0 0 155
>>>>>>> END
>>>>>>> END
>>>>>>> DEBUG 5
>>>>>>> END # Layer
>>>>>>> What is wrong with my FES filter? How can I make it to run?
>>>>>>> Thanks a lot,
>>>>>>> Michal
>>>>>>> _______________________________________________
>>>>>>> mapserver-users mailing list
>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
