[mapserver-users] msQueryByFilter(): Search returned no results.
Michal Šrédl
michal.sredl at gmail.com
Fri Aug 26 14:08:48 EDT 2011
Hi Steve,
for epsg:4326 and url
http://localhost//cgi-bin/ows?mode=itemnquery&qlayer=typ&qitem=zver&qstring=2
it says
msQueryByAttributes(): Search returned no results. No matching
record(s) found, layer and area of interest do not overlap.
Cheers,
Mike
2011/8/26 Steve Lime <sdlime at gmail.com>:
> You must have a default mapfile set in apache, that's cool. Use the second URL.
> Change qstring_validation to qstring_validation_pattern from my first
> message, my mistake.
> Steve
> 2011/8/26 Michal Šrédl <michal.sredl at gmail.com>:
>> Hi Steve,
>> regardless of the projection settings, I get the following result:
>> For
>> http://localhost//cgi-bin/ows?map=mapfile&mode=itemnquery&qlayer=typ&qitem=zver&qstring=2
>> I see
>> msLoadMap(): Regular expression error. MS_DEFAULT_MAPFILE_PATTERN
>> validation failed. msEvalRegex(): Regular expression error. String
>> failed expression test.
>> And for
>> I see
>> mapserv(): Web application error. Parameter 'qstring' value fails to
>> validate. msValidateParameter(): Regular expression error. Parameter
>> pattern validation failed.
>> Cheers,
>> Michal
>>> I would agree this sounds like a bug. The map extent *should* be
>>> projected to the layer extent and that's what's used to identify
>>> candidate features. Can you check what happens with a native mapserver
>>> attribute query in this case? If possible try this:
>>> 1) set your MAP projection back to geographic, and restore your
>>> geographic map extent.
>>> 2) add this line to the layer metadata 'qstring_validation' '^[0-9]$'
>>> 3) go to the following URL:
>>> http://localhost//cgi-bin/ows?map=[yourmapfile]&mode=itemnquery&qlayer=typ&qitem=zver&qstring=2
>>> and see what happens.
>>> This will run a different query function msQueryByAttributes() that's
>>> not new to 6.0.x.
>>> Steve
>>>> Hi Jukka,
>>>> the current settings returns expected result with &srsName=EPSG:4326
>>>> as well. The original settings doesn't work neither with
>>>> &srsName=EPSG:4326 nor &srsName=EPSG::102067.
>>>> Yes, it looks like there would be a problem in case of several WFS
>>>> layers with different projections of the source data.
>>>> Cheers,
>>>> Mike
>>>> 2011/8/26 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>:
>>>>> Hi,
>>>>> Good that you could make it to work. However, this feels maybe like a bug if it means that using ogc:PropertyIsEqualTo filter without any other filter works only if projection of the source data is the same than the default output projection from WFS.
>>>>> Could you have one more trial with the original settings and see if adding &srsName=EPSG:4326 or &srsName=EPSG::102067 is changing anything? And also if your current setting gives correct result with &srsName=EPSG:4326.
>>>>> -Jukka Rahkonen.
>>>>> Michal Šrédl wrote:
>>>>>> Hi all,
>>>>>> problem solved. I needed to set:
>>>>>> EXTENT -905000 -1230000 -400000 -900000
>>>>> and
>>>>> PROJECTION
>>>>> ## "init=epsg:4326"
>>>>> "init=epsg:102067"
>>>>> END
>>>>> (Epsg 102067 is the projection of the layer being filtered.)
>>>>> Thank you very much again,
>>>>> Michal
>>>>> 2011/8/25 Michal Šrédl <michal.sredl at gmail.com>:
>>>>>> Hi Steve,
>>>>>> Thanks a lot. The extent should be large enough to encompass all the
>>>>>> features. Here comes the whole mapfile:
>>>>>> MAP
>>>>>> NAME "MIS WFS Server"
>>>>>> STATUS ON
>>>>>> SIZE 500 500
>>>>>> EXTENT -180 -90 180 90
>>>>>> SHAPEPATH "data/"
>>>>>> IMAGECOLOR 255 255 255
>>>>>> CONFIG MS_ERRORFILE "log/mapserv.log"
>>>>>> DEBUG 5
>>>>>> WEB
>>>>>> IMAGEPATH "/var/www/tmp/"
>>>>>> IMAGEURL "/tmp/"
>>>>>> METADATA
>>>>>> "wfs_title" "MIS WFS Server" ## REQUIRED
>>>>>> "wfs_onlineresource" "http://127.0.0.1/cgi-bin/ows?"
>>>>>> "wfs_srs" "EPSG:4326 EPSG:102067"
>>>>>> "wms_srs" "EPSG:4326 EPSG:102067" ## Recommended
>>>>>> "wcs_srs" "EPSG:4326 EPSG:102067" ## Recommended
>>>>>> "ows_enable_request" "*"
>>>>>> "ows_updatesequence" "2011-29-05T00:24:00"
>>>>>> END
>>>>>> END
>>>>>> PROJECTION
>>>>>> "init=epsg:4326"
>>>>>> END
>>>>>> LAYER
>>>>>> NAME "typ"
>>>>>> METADATA
>>>>>> "wfs_title" "Typologie" ## REQUIRED
>>>>>> "wfs_include_items" "all"
>>>>>> "gml_featureid" "CISLO" ## REQUIRED
>>>>>> "gml_include_items" "all" ## Optional (serves all attributes for layer)
>>>>>> "gml_types" "auto"
>>>>>> "gml_geometries" "msGeometry"
>>>>>> "gml_msGeometry_type" "polygon"
>>>>>> END
>>>>>> DATA typ.shp
>>>>>> TYPE POLYGON
>>>>>> STATUS ON
>>>>>> PROJECTION
>>>>>> "init=epsg:102067"
>>>>>> END
>>>>>> DUMP TRUE ## REQUIRED
>>>>>> CLASS
>>>>>> NAME "Typ"
>>>>>> STYLE
>>>>>> COLOR 0 0 155
>>>>>> OUTLINECOLOR 120 120 120
>>>>>> END
>>>>>> TEMPLATE "templates/typ_zver.html"
>>>>>> END
>>>>>> DEBUG 5
>>>>>> END # Layer
>>>>>> LAYER
>>>>>> NAME "hsrs"
>>>>>> TYPE RASTER
>>>>>> STATUS ON
>>>>>> CONNECTION "http://www.bnhelp.cz/cgi-bin/crtopo?"
>>>>>> DEBUG ON
>>>>>> CONNECTIONTYPE WMS
>>>>>> METADATA
>>>>>> "wms_srs" "EPSG:4326"
>>>>>> "wms_name" "obce,kraje,hr_cr,sidla,doprava"
>>>>>> "wms_title" "CR Topo"
>>>>>> "wms_server_version" "1.1.1"
>>>>>> "wms_format" "image/png"
>>>>>> "wms_latlonboundingbox" "11.9384 48.2337 18.957 51.3549"
>>>>>> END
>>>>>> END
>>>>>> END # Map File
>>>>>> Cheers,
>>>>>> Michal
>>>>>> 2011/8/25 Steve Lime <sdlime at gmail.com>:
>>>>>>> What is your default EXTENT set to in your mapfile? It should be large enough to encompass all features. - Steve
>>>>>>> Sent from my iPad
>>>>>>> On Aug 24, 2011, at 7:58 AM, Michal Šrédl <michal.sredl at gmail.com> wrote:
>>>>>>>> Hi all,
>>>>>>>> I am trying to use FES filter for WFS layer and get no result, even
>>>>>>>> thought I should get one.
>>>>>>>> In my browser, I request
>>>>>>>> http://localhost//cgi-bin/ows?&REQUEST=GetFeature&VERSION=1.1.0&SERVICE=WFS&TYPENAME=typ&FILTER=<ogc:Filter
>>>>>>>> xmlns:ogc="http://www.opengis.net/ogc"><ogc:PropertyIsEqualTo><ogc:PropertyName>ZVER</ogc:PropertyName><ogc:Literal>2</ogc:Literal></ogc:PropertyIsEqualTo></ogc:Filter>
>>>>>>>> and get
>>>>>>>> <wfs:FeatureCollection
>>>>>>>> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>>>>>>>> xmlns:gml="http://www.opengis.net/gml"
>>>>>>>> xmlns:wfs="http://www.opengis.net/wfs"
>>>>>>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>>>>>> xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver
>>>>>>>> http://127.0.0.1/cgi-bin/ows?SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=typ&OUTPUTFORMAT=text/xml;%20subtype=gml/3.1.1
>>>>>>>> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
>>>>>>>> <gml:boundedBy>
>>>>>>>> <gml:Null>missing</gml:Null>
>>>>>>>> </gml:boundedBy>
>>>>>>>> </wfs:FeatureCollection>
>>>>>>>> even though I do know, that features with ZVER=2 do exist.
>>>>>>>> In the mapserver log file, I get
>>>>>>>> [Wed Aug 24 14:48:52 2011].296607 msQueryByFilter(): Search returned
>>>>>>>> no results. No matching record(s) found.
>>>>>>>> [Wed Aug 24 14:48:52 2011].296747 mapserv request processing time
>>>>>>>> (msLoadMap not incl.): 0.002s
>>>>>>>> [Wed Aug 24 14:48:52 2011].296764 msFreeMap(): freeing map at 0x2783120.
>>>>>>>> [Wed Aug 24 14:48:52 2011].296773 freeLayer(): freeing layer at 0x278b570.
>>>>>>>> I have checked http://mapserver.org/errors.html#id2 with similar error
>>>>>>>> "msQueryByPoint: search returned no results" and tried to create a
>>>>>>>> simple template:
>>>>>>>> <!-- MapServer Template -->
>>>>>>>> <tr>
>>>>>>>> <td>[lrn]</td>
>>>>>>>> <td>[ZVER]</td>
>>>>>>>> </tr>
>>>>>>>> but with no effect.
>>>>>>>> In the mapfile, there is
>>>>>>>> LAYER
>>>>>>>> NAME "typ"
>>>>>>>> METADATA
>>>>>>>> "gml_types" "auto"
>>>>>>>> END
>>>>>>>> DATA typ.shp
>>>>>>>> TYPE POLYGON
>>>>>>>> STATUS ON
>>>>>>>> PROJECTION
>>>>>>>> "init=epsg:102067"
>>>>>>>> END
>>>>>>>> CLASS
>>>>>>>> NAME "Typ"
>>>>>>>> STYLE
>>>>>>>> COLOR 0 0 155
>>>>>>>> END
>>>>>>>> END
>>>>>>>> DEBUG 5
>>>>>>>> END # Layer
>>>>>>>> What is wrong with my FES filter? How can I make it to run?
>>>>>>>> Thanks a lot,
>>>>>>>> Michal
>>>>>>>> _______________________________________________
>>>>>>>> mapserver-users mailing list
>>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
