[mapserver-users] Problem GetFeature with geom filter on WFS
Emmanuel Belo
emmanuel.belo at camptocamp.com
Tue Aug 23 12:11:28 EDT 2011
is anyone of the community interested in fixing this issue in Mapserver? We
could remove the limit, but having a first BBOX filter in PostGIS would be a
good solution to select candidates for mapserver to do the precise
geographical filtering.
Please contact me, I could provide some funding for this issue to be solved.
Best regards,
Emmanuel Belo
On 18 August 2011 18:23, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
> I agree that if Mapserver is doing the final filtering then passing
> maxFeatures="100" value for the query selecting the candidates is not right.
> But have you tested what happens if you run your WFS query without
> maxFeatures? It would be good to know if the result set is OK then.
> -Jukka Rahkonen-
> Stéphane Brunner wrote:
> > Hello Steve,
> > Sorry for the delay. I as on holiday last couple of weeks but the
> > issue is still a blocker for us.
> > Your say « PostGIS should be returning an appropriate set of candidate
> > features » but with our request PostGIS returns only the 100 first
> > features (a subset of all features) without taking any geographical
> > aspect into account. MapServer filters them correctly but as we get
> > only the 100 first results from the DB, we miss many objects and/or
> > they are not related to the area where we want to apply a geographical
> > filter. We've done a test on how MapServer handles the 100 first
> > results and it's working.
> > We also tested the behavior with a SHP file and it works like a charm,
> > there is no limitation. For our understanding, there is an issue in
> > the way mapserver pass the query to PostGIS as there is an
> > inappropriate LIMIT value in the SQL statement and mapserver doesn't
> > seem to pass a BBOX in order to prefilter the set in the DB.
> > Best regards
> > Stéphane Brunner
> > 2011/7/30 Steve Lime <sdlime at gmail.com>:
> > > The filter encoding code only translates certain things
> > into native SQL, the rest is handled in a uniform way within
> > MapServer. Hopefully this will change over time and more
> > processing will be moved to the database but there hasn't
> > been time to do that yet, maybe for 6.2.
> > features for MapServer to perform additional filtering.
> > Shapefiles work the same way. If you look at the SQL executed
> > by Postgres you should see all of the matching features plus
> > a few more.
> > > Steve
> > > Sent from my iPad
> > > On Jul 28, 2011, at 9:18 AM, Stéphane Brunner
> > <stephane.brunner at camptocamp.com> wrote:
> > >> Hello,
> > >> I log the sql request on spatial filter and I have this:
> > >> select
> > "oid","nummer","gemeinde","gueltigkeit","flgrundb","quote","ei
> > gentuemer","adresse_lang",encode(ST_AsBinary(ST_Force_2D("geom
> "),'NDR'),'hex')
> > >> as geom,"oid" from (SELECT oid, t1.geom, t1.nummer, t2.gemeinde,
> > >> t1.gueltigkeit1_txt as gueltigkeit, t2.flgrundb,
> > ((t2.zaehler::text ||
> > >> '/'::text) || t2.nenner::text) AS quote, t2.eigentuemer,
> > >> (((t2.adresse::text || ', '::text) || t2.plz::text) || '
> > '::text) ||
> > >> t2.ort::text AS adresse_lang FROM
> > av.liegenschaften_liegenschaft_area
> > >> as t1, av.view_gemlis_geomaste_parzelle as t2 WHERE
> > t1.gdid = t2.gdeid
> > >> and t1.nummer = t2.parznr::text) AS foo where geom &&
> > >> GeomFromText('POLYGON((620000 218000,620000 278000,690000
> > >> 278000,690000 218000,620000 218000))',-1) limit 100
> > >> I didn't see any postggis filter than I try to do a
> > spatial filter on
> > >> one of the 100 first results
> > >> Than I have a correct result ...
> > >> Than why mapserver doesn't use postgis spatial filter ?
> > Does I miss something ?
> > >> Thank-you in advance
> > >> Stéphane Brunner
> > >> 2011/7/26 Stéphane Brunner <stephane.brunner at camptocamp.com>:
> > >>> Hello,
> > >>> I just test it with a shape file, and it's working...
> > >>> I will investigate a little bit more to know why it's not
> > working with postgres.
> > >>> Sincerely
> > >>> Stéphane Brunner
> > >>> 2011/7/25 Steve Lime <sdlime at gmail.com>:
> > >>>> Never mind on version, I saw 6.0.0 in the response... ;-) Steve
> > >>>> On Mon, Jul 25, 2011 at 6:19 AM, Stéphane Brunner
> > >>>>> Hello,
> > >>>>> I have the mapfile [0]. when I done a GetFeature on the
> > nummer [1] I
> > >>>>> have 4 results [2] (with duplicate but it's an other issue).
> > >>>>> When I done a spatial filter [3] I have no results [4]
> > but I should
> > >>>>> have at least one result ...
> > >>>>> Thanks in advance for having a look on this issue.
> > >>>>> Sincerely yours
> > >>>>> Stéphane Brunner
> > >>>>> Following: specified, GetCapabilities [5],
> > describefeaturetype [6].
> > >>>>> mapfile [0]:
> > >>>>> MAP
> > >>>>> NAME "map"
> > >>>>> EXTENT 620000 218000 690000 278000
> > >>>>> UNITS METERS
> > >>>>> IMAGETYPE jpeg
> > >>>>> RESOLUTION 72
> > >>>>> DEFRESOLUTION 72
> > >>>>> IMAGECOLOR 255 255 255
> > >>>>> STATUS ON
> > >>>>> FONTSET "fonts.conf"
> > >>>>> SYMBOLSET "symbole.sym"
> > >>>>> MAXSIZE 5000
> > >>>>> PROJECTION
> > >>>>> "init=epsg:21781"
> > >>>>> END
> > >>>>> # Used by overlays
> > >>>>> OUTPUTFORMAT
> > >>>>> NAME png256
> > >>>>> DRIVER AGG/PNG
> > >>>>> MIMETYPE "image/png256"
> > >>>>> IMAGEMODE RGBA
> > >>>>> EXTENSION "png"
> > >>>>> FORMATOPTION "INTERLACE=OFF"
> > >>>>> FORMATOPTION "QUANTIZE_FORCE=ON"
> > >>>>> FORMATOPTION "QUANTIZE_DITHER=OFF"
> > >>>>> FORMATOPTION "QUANTIZE_COLORS=256"
> > >>>>> END
> > >>>>> OUTPUTFORMAT
> > >>>>> NAME png
> > >>>>> DRIVER AGG/PNG
> > >>>>> MIMETYPE "image/png"
> > >>>>> IMAGEMODE RGBA
> > >>>>> EXTENSION "png"
> > >>>>> END
> > >>>>> WEB
> > >>>>> METADATA
> > >>>>> "ows_title" "map"
> > >>>>> "ows_srs" "epsg:21781"
> > >>>>> "ows_encoding" "UTF-8"
> > >>>>> "wms_feature_info_mime_type"
> > "application/vnd.ogc.gml"
> > >>>>> "wms_enable_request" "*"
> > >>>>> "ows_enable_request" "*"
> > >>>>> "gml_include_items" "all"
> > >>>>> "gml_featureid" "id"
> > >>>>> "wfs_title" "map"
> > >>>>> "wfs_srs" "epsg:21781"
> > >>>>> END
> > >>>>> IMAGEPATH '/var/tmp/'
> > >>>>> END
> > >>>>> LEGEND
> > >>>>> IMAGECOLOR 240 240 240
> > >>>>> LABEL
> > >>>>> FONT arial
> > >>>>> ANTIALIAS true
> > >>>>> TYPE truetype
> > >>>>> SIZE 9
> > >>>>> COLOR 0 0 0
> > >>>>> END
> > >>>>> END
> > >>>>> LAYER
> > >>>>> NAME "Liegenschaft_Query"
> > >>>>> TYPE POLYGON
> > >>>>> STATUS ON
> > >>>>> TEMPLATE fooOnlyForWMSGetFeatureInfo
> > >>>>> CONNECTIONTYPE postgis
> > >>>>> PROCESSING "CLOSE_CONNECTION=DEFER"
> > >>>>> CONNECTION "user=www-data password=www-data dbname=dev
> > host=localhost"
> > >>>>> DATA "geom from (SELECT oid, t1.geom, t1.nummer FROM
> > >>>>> av.view_i_liegenschaft_all AS t1) AS foo using unique oid using
> > >>>>> SRID=-1"
> > >>>>> # GROUP "TOPIC_Liegenschaften_LN"
> > >>>>> METADATA
> > >>>>> "ows_title" "Liegenschaft_Query"
> > >>>>> "id_attribute_string" "oid"
> > >>>>> "ows_featureid" "oid"
> > >>>>> "ows_geometries" "geom"
> > >>>>> "ows_geom_type" "polygon"
> > >>>>> "query_returned_attributes" "nummer"
> > >>>>> "gml_include_items" "oid,nummer,geom"
> > >>>>> "gml_geometries" "geom"
> > >>>>> "gml_geom_type" "polygon"
> > >>>>> "gml_nummer_type" "Character"
> > >>>>> #"gml_groups" "TOPIC_Liegenschaften_LN"
> > >>>>> "gml_featureid" "oid"
> > >>>>> "wfs_title" "Liegenschaft_Query"
> > >>>>> END
> > >>>>> DUMP TRUE
> > >>>>> PROJECTION
> > >>>>> "init=epsg:21781"
> > >>>>> END
> > >>>>> CLASS
> > >>>>> NAME "Liegenschaft"
> > >>>>> STYLE
> > >>>>> SYMBOL "circle"
> > >>>>> SIZE 3
> > >>>>> OUTLINECOLOR 0 0 0
> > >>>>> END
> > >>>>> END
> > >>>>> END
> > >>>>> END
> > >>>>> query on the nummer [1]:
> > >>>>> <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs"
> > service="WFS"
> > >>>>> version="1.0.0" maxFeatures="100"
> > >>>>> xsi:schemaLocation="http://www.opengis.net/wfs
> > >>>>> http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"
> > >>>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> > >>>>> <wfs:Query typeName="feature:Liegenschaft_Query"
> > >>>>> xmlns:feature="http://mapserver.gis.umn.edu/mapserver">
> > >>>>> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
> > >>>>> <ogc:PropertyIsEqualTo>
> > >>>>> <ogc:PropertyName>nummer</ogc:PropertyName>
> > >>>>> <ogc:Literal>3634</ogc:Literal>
> > >>>>> </ogc:PropertyIsEqualTo>
> > >>>>> </ogc:Filter>
> > >>>>> </wfs:Query>
> > >>>>> </wfs:GetFeature>
> > >>>>> response on the nummer [2]:
> > >>>>> <?xml version='1.0' encoding="UTF-8" ?>
> > >>>>> <wfs:FeatureCollection
> > >>>>> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
> > >>>>> xmlns:gml="http://www.opengis.net/gml"
> > >>>>> http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
> > http://c2cpc89.camptocamp.com/sbrunner/mapserv?SERVICE=WFS&
> ;VERSION=1.0.0>
> &REQUEST=DescribeFeatureType&TYPENAME=feature:Liegensc
> > haft_Query&OUTPUTFORMAT=XMLSCHEMA">
> > >>>>> <gml:boundedBy>
> > >>>>> <gml:Box srsName="EPSG:21781">
> > >>>>> <gml:coordinates>661054.808000,244611.321000
> > >>>>> 663053.704000,244888.622000</gml:coordinates>
> > >>>>> </gml:Box>
> > >>>>> </gml:boundedBy>
> > >>>>> <gml:featureMember>
> > >>>>> <ms:Liegenschaft_Query fid="Liegenschaft_Query.2380997">
> > >>>>> <gml:boundedBy>
> <gml:coordinates>661054.808000,244854.251000
> > >>>>> 661088.687000,244888.622000</gml:coordinates>
> > >>>>> </gml:Box>
> > >>>>> </gml:boundedBy>
> > >>>>> <ms:geom>
> > >>>>> <gml:Polygon srsName="EPSG:21781">
> > >>>>> <gml:outerBoundaryIs>
> > >>>>> <gml:LinearRing>
> > >>>>> <gml:coordinates>661076.579000,244888.622000
> > >>>>> 661054.808000,244875.484000 661062.744000,244858.448000
> > >>>>> 661064.653000,244854.251000 661088.687000,244869.173000
> > >>>>> 661076.579000,244888.622000 </gml:coordinates>
> > >>>>> </gml:LinearRing>
> > >>>>> </gml:outerBoundaryIs>
> > >>>>> </gml:Polygon>
> > >>>>> </ms:geom>
> > >>>>> <ms:oid>2380997</ms:oid>
> > >>>>> <ms:nummer>3634</ms:nummer>
> > >>>>> </ms:Liegenschaft_Query>
> > >>>>> </gml:featureMember>
> > >>>>> <gml:featureMember>
> > >>>>> <gml:boundedBy>
> > >>>>> </gml:Box>
> > >>>>> </gml:boundedBy>
> > >>>>> <ms:geom>
> > >>>>> <gml:LinearRing>
> > >>>>> </gml:LinearRing>
> > >>>>> </gml:Polygon>
> > >>>>> </ms:geom>
> > >>>>> <gml:featureMember>
> > >>>>> <ms:Liegenschaft_Query fid="Liegenschaft_Query.2384539">
> > >>>>> <gml:boundedBy>
> <gml:coordinates>663017.565000,244611.321000
> > >>>>> 663053.704000,244650.084000</gml:coordinates>
> > >>>>> </gml:Box>
> > >>>>> </gml:boundedBy>
> > >>>>> <ms:geom>
> > >>>>> <gml:LinearRing>
> > >>>>> <gml:coordinates>663017.565000,244635.722000
> > >>>>> 663033.235000,244611.321000 663045.949000,244619.485000
> > >>>>> 663053.704000,244626.417000 663034.337000,244650.084000
> > >>>>> 663017.565000,244635.722000 </gml:coordinates>
> > >>>>> </gml:LinearRing>
> > >>>>> </gml:Polygon>
> > >>>>> </ms:geom>
> > >>>>> <ms:oid>2384539</ms:oid>
> > >>>>> <gml:featureMember>
> > >>>>> <gml:boundedBy>
> > >>>>> </gml:Box>
> > >>>>> </gml:boundedBy>
> > >>>>> <ms:geom>
> > >>>>> <gml:LinearRing>
> > >>>>> </gml:LinearRing>
> > >>>>> </gml:Polygon>
> > >>>>> </ms:geom>
> > >>>>> </wfs:FeatureCollection>
> > >>>>> query with spatial filter [3]:
> > service="WFS"
> > >>>>> <ogc:Intersects>
> > >>>>> <ogc:PropertyName>geom</ogc:PropertyName>
> > >>>>> <gml:Point xmlns:gml="http://www.opengis.net/gml"
> > >>>>> <gml:coordinates decimal="." cs="," ts="
> > >>>>> ">661070.024,244872.084</gml:coordinates>
> > >>>>> </gml:Point>
> > >>>>> </ogc:Intersects>
> > >>>>> </ogc:Filter>
> > >>>>> </wfs:Query>
> > >>>>> </wfs:GetFeature>
> > >>>>> response with spatial filter [4]:
> ;VERSION=1.0.0>
> > >>>>> <gml:boundedBy>
> > >>>>> <gml:null>missing</gml:null>
> > >>>>> </gml:boundedBy>
> > >>>>> GetCapabilities [5]:
> > >>>>> <WFS_Capabilities
> > >>>>> version="1.0.0"
> > >>>>> updateSequence="0"
> > >>>>> xmlns="http://www.opengis.net/wfs"
> > >>>>> http://schemas.opengis.net/wfs/1.0.0/WFS-capabilities.xsd">
> > >>>>> <!-- MapServer version 6.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> > >>>>> SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=OPENGL
> > >>>>> SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI
> > SUPPORTS=WMS_SERVER
> > >>>>> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> > >>>>> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
> > >>>>> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR
> > INPUT=GDAL
> > >>>>> INPUT=SHAPEFILE -->
> > >>>>> <Service>
> > >>>>> <Name>MapServer WFS</Name>
> > >>>>> <Title>Amtliche Vermessung</Title>
> > >>>>> <Abstract>Die amtliche Vermessung nach DM01 Darstellung als WMS
> > >>>>> Dienst für MapFish Projekte</Abstract>
> > <OnlineResource>http://c2cpc89.camptocamp.com/sbrunner/mapserv
> ?</OnlineResource>
> > >>>>> </Service>
> > >>>>> <Capability>
> > >>>>> <Request>
> > >>>>> <GetCapabilities>
> > >>>>> <DCPType>
> > >>>>> <HTTP>
> > >>>>> <Get
> > >>>>> onlineResource="http://c2cpc89.camptocamp.com/sbrunner/mapserv?"
> > >>>>> </HTTP>
> > >>>>> </DCPType>
> > >>>>> <DCPType>
> > >>>>> <HTTP>
> > >>>>> <Post
> > onlineResource="http://c2cpc89.camptocamp.com/sbrunner/mapserv?" />
> > >>>>> </HTTP>
> > >>>>> </DCPType>
> > >>>>> </GetCapabilities>
> > >>>>> <DescribeFeatureType>
> > >>>>> <SchemaDescriptionLanguage>
> > >>>>> <XMLSCHEMA/>
> > >>>>> </SchemaDescriptionLanguage>
> > >>>>> <DCPType>
> > >>>>> <HTTP>
> > >>>>> <Get
> > >>>>> </HTTP>
> > >>>>> </DCPType>
> > >>>>> <DCPType>
> > >>>>> <HTTP>
> > >>>>> <Post
> > >>>>> </HTTP>
> > >>>>> </DCPType>
> > >>>>> </DescribeFeatureType>
> > >>>>> <GetFeature>
> > >>>>> <ResultFormat>
> > >>>>> <GML2/>
> > >>>>> </ResultFormat>
> > >>>>> <DCPType>
> > >>>>> <HTTP>
> > >>>>> <Get
> > >>>>> </HTTP>
> > >>>>> </DCPType>
> > >>>>> <DCPType>
> > >>>>> <HTTP>
> > >>>>> <Post
> > >>>>> </HTTP>
> > >>>>> </DCPType>
> > >>>>> </GetFeature>
> > >>>>> </Request>
> > >>>>> </Capability>
> > >>>>> <FeatureTypeList>
> > >>>>> <Operations>
> > >>>>> <Query/>
> > >>>>> </Operations>
> > >>>>> <FeatureType>
> > >>>>> <Name>Liegenschaft_Query</Name>
> > >>>>> <Title>Liegenschaft_Query</Title>
> > >>>>> <SRS>epsg:21781</SRS>
> > >>>>> <LatLongBoundingBox minx="620000" miny="218000"
> > maxx="690000"
> > >>>>> maxy="278000" />
> > >>>>> </FeatureType>
> > >>>>> <FeatureType>
> > >>>>> <Name>Liegenschaft_Query_ALL</Name>
> > >>>>> <Title>Liegenschaft_Query_ALL</Title>
> > maxx="690000"
> > >>>>> maxy="278000" />
> > >>>>> </FeatureType>
> > >>>>> </FeatureTypeList>
> > >>>>> <ogc:Filter_Capabilities>
> > >>>>> <ogc:Spatial_Capabilities>
> > >>>>> <ogc:Spatial_Operators>
> > >>>>> <ogc:Equals/>
> > >>>>> <ogc:Disjoint/>
> > >>>>> <ogc:Touches/>
> > >>>>> <ogc:Within/>
> > >>>>> <ogc:Overlaps/>
> > >>>>> <ogc:Crosses/>
> > >>>>> <ogc:Intersect/>
> > >>>>> <ogc:Contains/>
> > >>>>> <ogc:DWithin/>
> > >>>>> <ogc:BBOX/>
> > >>>>> </ogc:Spatial_Operators>
> > >>>>> </ogc:Spatial_Capabilities>
> > >>>>> <ogc:Scalar_Capabilities>
> > >>>>> <ogc:Logical_Operators />
> > >>>>> <ogc:Comparison_Operators>
> > >>>>> <ogc:Simple_Comparisons />
> > >>>>> <ogc:Like />
> > >>>>> <ogc:Between />
> > >>>>> </ogc:Comparison_Operators>
> > >>>>> </ogc:Scalar_Capabilities>
> > >>>>> </ogc:Filter_Capabilities>
> > >>>>> </WFS_Capabilities>
> > >>>>> describefeaturetype [6]:
> > >>>>> <schema
> > >>>>> targetNamespace="http://mapserver.gis.umn.edu/mapserver"
> > >>>>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> > >>>>> xmlns="http://www.w3.org/2001/XMLSchema"
> > >>>>> elementFormDefault="qualified" version="0.1" >
> > >>>>> <import namespace="http://www.opengis.net/gml"
> schemaLocation="http://schemas.opengis.net/gml/2.1.2/feature.xsd"
> > >>>>> <element name="Liegenschaft_Query"
> > >>>>> type="ms:Liegenschaft_QueryType"
> > >>>>> substitutionGroup="gml:_Feature" />
> > >>>>> <complexType name="Liegenschaft_QueryType">
> > >>>>> <complexContent>
> > >>>>> <extension base="gml:AbstractFeatureType">
> > >>>>> <sequence>
> > >>>>> <element name="geom" type="gml:PolygonPropertyType"
> > >>>>> minOccurs="0" maxOccurs="1"/>
> > >>>>> <element name="oid" type="string"/>
> > >>>>> <element name="nummer" type="Character"/>
> > >>>>> </sequence>
> > >>>>> </extension>
> > >>>>> </complexContent>
> > >>>>> </complexType>
> > >>>>> </schema>
> > >>>>> camptocamp.com
> > >>>>> mapfish.org
> > >>>>> _______________________________________________
> > >>>>> mapserver-users mailing list
> > >>>>> mapserver-users at lists.osgeo.org
> > >>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> > >>> camptocamp.com
> > >>> mapfish.org
> > >> camptocamp.com
> > >> mapfish.org
> > camptocamp.com
> > mapfish.org
Camptocamp SA
Emmanuel BELO
PSE A
CH-1015 Lausanne
+41 21 619 10 25 (direct)
+41 21 619 10 10 (centrale)
+41 21 619 10 00 (fax)
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110823/bd0e413c/attachment-0001.html
